Old 05-18-2012, 09:48 PM
KYD's Avatar
KYD KYD is offline
Vehicle: 2004 Dodge Ram
Color: Slate Gray
KYD is on a distinguished road
Default 18" or 24" Magnaflow on my Hemi?
Looking to just swap out my muffler and get a lil more of a deep rummble throaty sound. Dont want anything super loud, obnoxious, or just simply retarded on there that sounds like @ss. Stock'r on there right now is a smidge over 24" 2.5 inlet and 2.5 outlet. So the 24" magnaflow would just simply bolt right up to the existing inlet and outlets. But would it give me the tone im looking for??? Ive seen videos online for the 18" Magnaflows and they sounds just like what im looking for. But id have to add exhuast pipe and only found it in videos with it as a dual set up on trucks. i dont have a dual exhaust and i have only enough $$$ to direct swap my muffler.
18" part # 11256
24" part # 12286
Old 05-18-2012, 10:41 PM
KYD's Avatar
KYD KYD is offline
Color: Slate Gray
and if a mod or admin see's this, could you possibly put it into the exhuast part of the forum. i didnt see it before i started this thread.
Old 05-19-2012, 12:00 AM
STERLING RAM 82's Avatar
STERLING RAM 82 STERLING RAM 82 is offline
Vehicle: 2011 Dodge Ram
Rep:27
STERLING RAM 82 is on a distinguished road
Go with the 18. The 24 isn't goin to give you the noticeable difference you are probably looking for. Do you still have your resonator on? If so, definitely go with the 18. That will give you a low rumble and a good growl when you open it up but keep it from being too loud. If you want it even louder, then you can always just take the resonator off.
Old 05-19-2012, 01:43 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
per your description, do the 24" (i run it), low muscular tone an not overbearing, keeps it quiet incab, I've run the 18" mag before and tho it sounds good on outside, the tone incab gre louder an louder to the point I wanted to swap it for a bigger mag. i truly enjoy how the rythmic v8 tone sounds on the inside with the 24"... don't use the resonator and if you don't mind not havin a tip, dump it over axle... also, it will get louder over time, just enough for my liking..
Old 05-19-2012, 10:22 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
i have the mufflex 24" on idlee its louder and driving around is also much louder than stock , at wot is loud,.
but i also had my back resonators remove
at idle i would says twice louder than stock
driving around much louder than stock, i did use to hear my exhause with the windows closed and i know i hear it no problem even when going easy on it
at wot well its loud.
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 05-19-2012, 01:16 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
id prolly go with the 18 inch if i were you bud i have the magnaflow cat back with the 22 i believe and im thinking about going with the 18 just to have a lil more rumble
Old 05-19-2012, 02:52 PM
Rep:27
Yep, I have the exact same setup on mine and it gives a nice low rumble but it is subtle. I have been thinking about switching out the muffler for the 18 as well but worried about drone since the catback come without the resonators. From what I have heard the 22" magnaflow w/o resonators sound pretty. Lose to the 18" muffler w/ resonators on. That's why I figured you wouldnt want to go with the 24" muffler swap.
Old 05-19-2012, 02:54 PM
Rep:27
Damn phone...that was supposed to say the catback sounds pretty close to...
Old 05-21-2012, 02:49 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
Default 18
Id go with the 18, have it on my truck and love it.
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 05-21-2012, 03:12 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
14...ain't that loud...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
