where does this vacuum line go? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-19-2012, 08:32 PM
96Sport 96Sport is offline
Vehicle: 1996 Dodge Ram
Trim Level: Laramie SLT Sport
96Sport is on a distinguished road
Default where does this vacuum line go?
'96Ram 1500 4x4 with 5.2 check-engine light is on for random (or maybe "ramdom") misfire. There's a rubber hose that runs from what I assume is the vacuum canister (mounted to frame near the fuel tank) to the firewall, just under the steering shaft. But it seems to end there; am I missing a section, and where should it attach?
Old 05-19-2012, 08:41 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2016 Ram 2500 4x4 LongHorn Meg
Trim Level: LongHorn
Rep:161
Burkdadhemi has a spectacular aura aboutBurkdadhemi has a spectacular aura about
Where is it coming from ?
2500 Megacab 4x4
Longhorn Brilliant Black Pearl 6.4L
Cattle Tan Interior
Old 05-19-2012, 08:50 PM
Rep:2920
I am only guessing
Look for a Charcoal canister
it may be nearer to the headlight
i searched some other forums & found this
The Charcoal "vapor" canister connects to the purge solenoid that is located on the rear drivers side of the manifold. It has 2 elbow connected hoses and a wiring harness connected to it. The capped off port in the manifold is very typical on these trucks.
Old 05-19-2012, 09:07 PM
Rep:2920
Vapor Canister Purge Solenoid image
http://www.partsgeek.com/gbproducts/...noid+2002+2001
the charcoal canister may also be called a
Vapor Canister
Old 05-20-2012, 12:59 PM
Thanks. One end of this tube does connect to the charcoal canister; the other end is just open, not connected to anything, in the firewall area (under the steering shaft). It doesn't look right; maybe this is the work of the previous owner...or maybe something has fallen off? I did locate the vapor cannister solenoid valve; both vacuum ports are already connected to other things. => can any of you guys with similar powertrain (1996 5.2 liter) check to see if you have an open hose too?
Old 05-20-2012, 02:16 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Traced mine...
Canister to where you have it open...It continues straight up and tracels under the cowl in the engine bay to the passenger's side of the engine. At the back of the passenger's side valve cover it connects to a rubber "t".
From the rubber "t" the small line goes to the back of the intake (you're on your own from there. It's Sunday and I don't want to go any further).
The larger line travels the distance of the valve cover to the front and connects to a blue double "L" vacuum port.
If you don't find any plugged ports there let me know and I'll break out the soap and water when I'm done...but only for another Ram.
(Now I KNOW that one was relevant)
Old 05-20-2012, 03:46 PM
Rep:2920
While i was reading from thar other forum
some people mentioned that their hoses ran down the drivers side all the way, while others ran over to the passenger side
Old 07-28-2012, 05:34 PM
derrik52 derrik52 is offline
Vehicle: dode 1997 ram 1500
Color: red
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
derrik52 is on a distinguished road
that vacuum line is just to reales vapor biuldup from the charcoal canister it is supose to just have a plug on the end of it. but dont worry its supose to be like that, at first looking at my truck i thought the same thing but did some research and sure enough thats how it is
