Old 05-20-2012, 03:53 PM
05 bee 05 bee is offline
Color: Deep water blue/light sandstone
05 bee is on a distinguished road
Default What is the difference in these lifts
Whats the difference between the BDS and the Zone 6" lifts for the 2010 ram other than the price
Old 05-20-2012, 06:35 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Mainly warranty. They both achieve the lift the same way with a strut spacer and preload spacer for the front. They both use the same springs for the rear. Zones rear cross member is straight instead of arched like BDS and every other companies kit.....prolly less ground clearance. I think BDS also comes with stainless replacement brake-lines and such. BDS is more of a "full" kit if you will. I think thats about it!
I didn't like Zones rear cross member, that pushed me away. Another thing I didnt like about Zone and BDS is their skid plate: It sits about 3.5" lower than my RCX skid plate. The finally thing was that they use a 4.5" strut spacer and a 5/8" preload spacer for the front lift. So if you wanna do Bilstiens your adding to a 4.5" Suspension lift unlike My RCX kit which uses a 5.5" strut spacer or PC strut spacer that's a hair over 5" and Fabtechs 5" strut spacer.
Happy Lifting!
[CENTER][SIGPIC][/SIGPIC]
Old 05-20-2012, 08:36 PM
Thanks..... What are the preload spacers for?.... I like the zone/BDS lifts because they offer a 3" rear spring .... My truck had such a rake to it I did a 2 1/2 level kit and i couldn't use the rear 1 1/2 rear..... I'm looking to make it sit like a power wagon with 35x12.5 18 ..... I'm not going off road with this truck
Old 05-20-2012, 08:41 PM
candy08's Avatar
Rep:213
They use the preload spacer to achieve an inch to inch and a half of your 6" suspension lift!
Old 05-20-2012, 08:52 PM
So if you preload the spring it makes the ride stiffer?..... And you said the other kits come with a 5 inch spacer so theses kits aren't a true 6" kit?
Old 05-20-2012, 08:55 PM
candy08's Avatar
Rep:213
Correct. None of the kits offered for the 4th Gen Rams are a true 6" kit. The closest is RCX followed by PC then Fabtech then Zone/BDS.
Old 05-20-2012, 09:20 PM
Thanks..... I want my truck level , like I said I did a 2 1/2 level to get me level .... I don't want to make the ride harsh so I need to see what lift to get now
Old 05-20-2012, 09:22 PM
Ace--'s Avatar
Ace-- Ace-- is offline
Vehicle: 2012 Ram 1500
Trim Level: LoneStar
Rep:55
Ace-- will become famous soon enough
Well looks like candy is helping you.. (Like he does with everyone) he's like the lift genius. lol!
Old 05-20-2012, 09:38 PM
Yes he she'd a lot of light on this for me
Old 05-20-2012, 09:46 PM
Candy... Knowing what I'm looking to acheive..... What lift would you sugg?
