Old 05-20-2012, 11:57 PM
bighemi04's Avatar
Rep:623
Default Transmission issue
I know this isnt a performance issue but you performance guys are infinitely more intelligent than anyone else on this site. My rear seal started going out so i took it and and had them replace the seal and do the fluid and filters at the same time. I get it back and two days after that my check engine light comes on, sorry haven't ran the code yet, and it dies out at a stop light or two on the way home. Concerned about it but chalked it up to bad gas. Well I get in it today and drive to the gas station with no problems. Drive it home and it slams into first gear going over a bump. come to the next stop sign and it wont shift out of first gear, pull over turn it off and restart it and it has no problem shifting. Any ideas?
Old 05-21-2012, 08:07 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
you need to pull the code. I'd also start by taking it back to the place that just did all your work.
Old 05-21-2012, 12:16 PM
bighemi04's Avatar
Rep:623
Yea I called them and they said they will look at it, that I probably have an electrical problem. I hope they don't expect me to pay for the diagnostic time. Ill pay for the parts but not the diagnostic.
Old 05-22-2012, 09:42 PM
bighemi04's Avatar
Rep:623
Pulled the code. p0876
Old 05-22-2012, 11:05 PM
CHVYKLR's Avatar
Rep:252
Transmmission fluid pressure sensor D range/performance problem
Old 05-22-2012, 11:09 PM
bighemi04's Avatar
Rep:623
i know that much, it is at the shop currently. i am not the most transmisson savvy guy and i am just trying to get an idea of what it could be so they dont screw me. thanks chvy
Old 05-22-2012, 11:31 PM
CHVYKLR's Avatar
Rep:252
Just type P0876 into google. The 4th link down is for a jeep forum and his case sounded like an easy fix.
I started clicking on some of the other links and it sounds like replacing that pressure sensor fixes it most of the time.
Old 05-22-2012, 11:34 PM
jnek09 jnek09 is offline
Vehicle: 2012 Ram 1500 Big Horn
Rep:35
jnek09 is on a distinguished road
I had similar problems with my transmission last year. Wouldn't shift out of first then different gears started flashing on the dash like I was manually shifting 4, 5 even though I was doing 10 mph in 1st. Shut it restarted and would be good for a few miles then happen again. Dealer dropped the pan and said the filter was clogged and not passing enough fluid...they did a full tune-up on the tranny and no problems since. Good luck...hopefully it's a small problem.
Old 05-22-2012, 11:43 PM
bighemi04's Avatar
Rep:623
yea i hope its something small. i mean it has to be something they did. and i hope they dont expect me to pay for their labor. parts i will cover but no labor. what will shock me the most is if it turns out to be something they did or didnt do, the shop is filled a porsche rally car and six different drag and muscle cars. all they do is race and they are damn good at it and if they cant install my filters right who knows what else they are good for. 112000 miles before that yielded not one slipped, missed, or slammed gear. i could hardly even feel it shift right when i got it back. thinking it is a filter issue.
Old 05-23-2012, 01:34 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
who did fluid/filter change, dealer or elsewhere, most likely it's the filters, 3rd party filters don't seem to seal that well and drops pressure which causes funny things to happen...shift delays, stalling etc...dodge even had a tsb years ago regarding filters, so much that they made a newer version to fix the problem... then again, I could be wrong
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
