Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 05-21-2012, 12:35 AM
okie rob okie rob is offline
Vehicle: 2007 Dodge Ram 2500 Mega Cab
Trim Level: Larmie
okie rob is on a distinguished road
Default No electircal, back left door
The back door of my mega cab seems to have lost ground. The speaker doesn't work, the cab light does not come on when you open the door (works on all the other doors), power door locks doesn't work on this door, and the window switch doesn't work either, but I can work the window from the drivers doors switches. The only thing I can think is it lost ground. Any ideas?
Old 05-23-2012, 11:11 AM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
You could have a broken wire in the rubber boot that goes from the cab to the door? If you pull the boot back a bit and give each wire a pull there could be one, (or more), broken. If this is the case it's a pretty easy fix.
[/SIGPIC]
Old 05-30-2012, 04:25 PM
mokin's Avatar
mokin mokin is offline
Rep:14
mokin is on a distinguished road
Yup most likely broken wire in the boot that goes from the door to the truck had same problem, so i checked inside the boot and i had three broken wires fixed it n broke again then put a little extension on the wire and haven't had any more problems, hope that helps
Old 04-02-2013, 10:29 PM
donnybrian donnybrian is offline
Vehicle: 2006 dodge 2500
donnybrian is on a distinguished road
Default this is what mine looked like. my door lock, and dome light were not working.
/Users/deniseosmond/Downloads/20130402_183153-1.jpg
Old 04-17-2013, 09:19 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Rep:194
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
+ 1 more on the broken wires. I just looked at mine because the power door lock was not working. I saw 3 repaired wires and 4 broken ones. Sounds like it is pretty common.
2007 ram 2500 mega cab, 6.7 cummings
