Headlights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 05-20-2012, 11:44 PM
Jodiwon's Avatar
Jodiwon Jodiwon is offline
Vehicle: 2012 Ram 1500 Express
Jodiwon is on a distinguished road
Default Headlights
How in the heck do you replace the light bulbs on the 2012 Ram? Do you have to take the whole assemble out?
Old 05-21-2012, 12:33 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Vehicle: 2017 Ram 1500 Crew 4x4
Rep:1276
You most certainly do!
Two schools of thought.... some take out the entire grill however if you have a long extension and some duct tape you can get the headlights out without going through the hassle of pulling the grill.
Big Red my old 2011 Sport
Old 05-21-2012, 05:28 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
its very easy to do. pull the plastic air dam off (4 push pins) I think their is 4 bolts holding the grill in. Then pull the bottom of the grill straight out. 2 spring snaps hold the bottom in. should be 2 bolts on each light. now the hard part. in the wheel well you will see a panel held in by a push pin, open the panel. first time take a flash light look in side you will see a white plastice flat piece that needs to be pushed up. once thats done the light will slide out. sounds complicated but its not. first light will be the hardest but once you get the hang of it its easy.
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
