Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 05-24-2012, 12:07 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
No you do not, you can purchase just the airbags, and fill them manually from an external air source, such as your home air compressor in your garage! We recommend the compressor for ease of use, but it is not necessary for the kit to work.
Air tanks are not needed either with TLC. TLC's powerful air springs level heavy loads with 20-30 psi - extremely low air pressure compared to every other system. So the compressor doesn't have to work hard and that's why TLC extends the standard 90 day compressor warranty to 2 years.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 05-24-2012, 01:53 PM
rickabev rickabev is offline
Rep:14
rickabev is on a distinguished road
On my 06 Tacoma I started out with just the bags and manually inflated them for a number of months. It worked and was functional but then I installed the Wireless Air compressor kit from Airlift and I really found it to be much more functional. I liked the ability to adjust the setup on the fly rather then pull into a service station and pump it up manually. I can't count the number of times I'd add 5 or 10 lbs of pressure to help with gear or tools in the back. Back then the wireless compressor was not nearly as expensive as it is now unfortunately. I think Suspensionconnection.com has it going to like $450 or so just for the compressor setup (no airbags).
You can definitely save some money doing a hard-wired one. The one that came with the TLC setup has worked great for me, and it wasn't that much more then just buying the airbags alone. It took me a bit longer to install because you have to go through the firewall when installing it, and I wanted to integrate it as best as possible for esthetics. It's always something you can add later on down the line, but with the deal TLC has going I doubt you could beat it later on.
Old 05-28-2012, 03:43 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Thx again Rick
Thx again Rick.
Trick install on the gauge and switches.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
Old 06-06-2012, 10:32 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Vehicle: 2014 Ram 2500 Laramie
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
this is what I like to read, nice to see a happy customer with this product, i'm glad i made the right choice going with TLC, I opted for the compressor kit.
I'm excited, it's killing me waiting for my kit to arrive hahahaa I'm like a kid the day before xmas hahaha, I will take a pic tonight and then tomorrow after the install (provided UPS actually shows up). The sag with my trailer isn't dangerous but annoying as heck, and I have bad add and things have to be perfect, which means the truck has to look stock even under load.
my set up is 32' 10" Keystone Passport Ultra-lite 5wheel 6360 lbs, hitch 1120
I can't wait..... hurry up UPS hahahahaha
Old 06-07-2012, 12:43 PM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
I am also looking into this system , how was UPS brokerage fees ? I am pulling a 255RKS sprinter at about the same weights give or take.
Old 06-07-2012, 01:32 PM
LC Hauler's Avatar
Rep:72
not sure yet, UPS hasn't called me to arrange brokerage, so I'm not sure yet, however I can't see it being anymore than $80 with taxes, I'm looking into brokering the package myself hrough a customs office here in Calgary.
Old 06-07-2012, 01:47 PM
dankent's Avatar
Rep:32
I see, thanks for the update.
Old 06-08-2012, 08:10 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
The biggest difference I see between the two pics is the angle of your trailer. In the first pic your trailer hitch looks almost level (where it should be). In the second pic the trailer hitch is nose high which is taking the weight off your truck. Just my observation
Old 06-09-2012, 01:04 AM
Rep:14
The hitch has not been adjusted in these photos and it therefore shows how much the airbags have adjusted the ride height. Basically comparing apples to apples. Leveling the trailer is a matter of adjusting a few bolts on the weight distribution hitch. Doing so will level the trailer but will also keep the truck level too.
Old 06-09-2012, 01:42 AM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Here's mine just last week.28 Foot 6400lbs Dry Reese WDH 1000lbs Spring Bars Airlift 1000 lbs Bags with about 15lbs . 4 Adults in Truck & about 1500lbs extra wieght in truck & trailer. Dead Level
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
