Old 05-21-2012, 11:21 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Default hhp phase limiter offering 30 rwhp alone.
So i was looking at highhorseperformace.com page and i saw "
HHP TESTING:
With our in-house test car, a 2009 5.7L VVT 6-Speed Challenger, we have dyno'd just this limiter by itself and seen a true 30rwhp gain (22rwhp STD Corrected) at the wheels. Tuning is required as this limiter will produce a check engine light without proper tuning. Contact HHP for all your tuning needs.
I was wondering if anybody else saw this and how they feel about it. If so This mod combined with ARH longtubes and a CAI would be rather impressive. And also do you guys think that with a piggyback set up one of the comp cams can be put into an 11 ram? Thanks
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 05-22-2012, 10:09 AM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
I honestly can't see just a phaser helping power, if anything, it would probably lose power at certain rpms since the cam wouldn't be allowed to optimize power over as wide an area.
Now, with it limited, timing that would normally cause piston to valve clearance issues could be used or a bigger cam itself. So with proper tuning, I could see increases. I know it mentions tuning but it sounds more like they're saying its just to get rid of the check engine light. They had to have played with more stuff than that.
2013 F-150 King Ranch 4wd 5.0
Old 05-22-2012, 01:56 PM
moparornocar72's Avatar
Rep:630
Just like trying to put smoke back in a cigarette, it ain't happening.
14.268 @ 95 MPH Full Trim
Old 05-22-2012, 05:58 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Makes since to me since the cam does not move as much the motor makes more power than stock. I can see how the stock phaser limiter is designed for fuel economy to retard the timing at low rpms and provide power under wot by advancing timing. Now if you add a cam phaser limiter which decreases the distance in degrees the cam can be manipulated it will allow the motor to spin up faster in much less time and that translates into more hp.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
