Old 05-22-2012, 05:51 PM
dozier68's Avatar
dozier68 dozier68 is offline
Vehicle: 2010 Dodge Ram 4X4 Crew Cab
dozier68 is on a distinguished road
Default LT vs P rated tires
I am curious as to what you guys run on your trucks. Is there an obvious advantage of one over the other? I know the LT's have a higher load capacity and stiffer sidewall, but will they last longer? Also, is there a noticeable difference in MPGs?
Cherry Bomb Vortex with 5" tips, 20% tint up front, Truck Champ nerf bars, AVS Vent Visors
Old 05-22-2012, 06:47 PM
Rep:2625
If both types of tire are new, & both have the same type of tread, either highway or all terrain, the slightly heavier LT will use more fuel, but the difference in MPG would be so slight, you would have to measure it in tank fulls, not per gallon
My Ram came with P rated tires, i drive a heck of a lot, like yesterday a job took me about 400 miles, most of the day i was on asphalt or concrete, but i was also on construction roads & parking areas. nails & screws were every where
P rated tires seem to reach out & grab sharp objects & if they hit a road hazard, they blow out
I switched to LT tires before the factory tires were even close to 1/2 worn
Old 05-23-2012, 09:08 AM
dozier68's Avatar
Thanks GTyankee that is the exact type of response I was hoping to get! My truck also came with the P-rated tires but I am considering upgrading to LTs when these wear out. I do alot of highway miles each day on my truck so that is where my concern came from if they will affect my MPG.
Old 05-23-2012, 12:07 PM
edd5's Avatar
edd5 edd5 is offline
Vehicle: 2012 Ram 1500 SLT
Color: grey
Rep:17
edd5 is on a distinguished road
"LT" means Light Truck. "P" means Passenger. The LTs are much tougher with better sidewalls. The "P" tire has a softer ride and is a lot cheaper than the LT. But with a "P" tire you can get what they call "impact bulges" in the sidewall from a pothole, curb, big rock, etc. These are not considered defects and are not covered by the tire manufacturers warranty. If you run on nice pavement all the time the "P" tires may be good for you. If you do any rough duty or off-roading an LT tire would be better. The 3/4 ton heavy duty trucks all come with LT tires. The 1/2 ton comes with P tires for the soft ride and low cost. I run LTs in my 1/2 ton truck.
Old 05-25-2012, 09:10 AM
JohnJr30236 JohnJr30236 is offline
Vehicle: 2004 Dodge Ram
Trim Level: QuadCab SLT Off-Road
Color: Dark Blue
JohnJr30236 is on a distinguished road
Not all brands of LT's are created equally. Make sure to read the tire sidewall to see how many plies of material they are made of. Most tires will be load range C,D, or E.......normally thats 6,8, and 10 ply rated. Some of your foreign brands seem to have their own grading system, such as a kumho load range E with only 6-7 plies of material. In your case i think tire brand/quality is more of a concern than load range.
2014 Ram 1500 Black Express RCSB 3.6L 8-spd
Old 05-25-2012, 09:13 AM
Color: Dark Blue
Check out www.treadwright.com for some pretty good deals. Ive had three sets of tires from them with zero problems. Right now i have the 315/70r17 guard dog's and i love them!
Old 05-25-2012, 03:27 PM
dozier68's Avatar
Those are some really great prices!! How many miles can you put on a set of those tires?
Old 05-25-2012, 03:54 PM
ALA1973's Avatar
ALA1973 ALA1973 is offline
Vehicle: 2012 dodge ram 4x4
Trim Level: big horn
Color: sagebrush Pearl
ALA1973 is on a distinguished road
if you use your truck as a truck go with LTs P rate tires are Passenger not for work they are softer for better ride not made to hold up to work
Old 05-25-2012, 04:05 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Picked up a small screw in my Wrangler HP' last week cost me $30.00 at Sears (only place I could find on Sunday who would fix it) I will be switching toi an LT tire when these are gone.. BTW this set of Wrangler's are doing great alreadt 12k on them and itlloks like these are going to go at least 40k. My last ones were all done in 32k off the 08. I wonder what the difference is?
Old 05-25-2012, 04:28 PM
Color: Dark Blue
I believe they are warrantied for 2 years/24k miles. My first set of warden a/t's got considerably more than that. I wanna say it had almost 32k on it when I changed them. But they were far from bald. Give them a call. They will take the time to explain the process. Some of the nicest people in the tire industry right there!
