Old 05-22-2012, 06:03 PM
Grubrunner's Avatar
Rep:3883
Default Volant CAI owners.....
Did any of you throw a code upon completion of your Volant CAI [160576] installation?
Grub out!
Old 05-22-2012, 06:10 PM
2500hd's Avatar
2500hd 2500hd is offline
Vehicle: 2010 Ram 2500 HD
Color: Austin Tan
Rep:32
2500hd is on a distinguished road
I have had mine on 2 weeks and no code. Any chance you left the key in the accessory mode when unpluggin IAT sensor? Or started it with the IAT still unplugged? Maybe check that connection and make sure its a good tight connection as that would be the only place I can think of that would set a code. Also try disconnecting the battery and resetting the system and seeing if the code returns.
-Amp Research-Fuel Offroad-Nitto-Diablo-Rigid Industries-Craven-CJC Offroad-Carli-BT-
Old 05-22-2012, 06:17 PM
Grubrunner's Avatar
Rep:3883
I don't have one.
I just got a call from a cousin in WV who just installed one and his truck [identical to mine in just about every way, except color] and threw an engine check code.
I told him I'd do some forum research and get back with him later tonight.
I went over some trouble shooting with him and he seems to have convered all his bases.
Grub out!
Old 05-22-2012, 07:18 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
Did you not properly unplug the negative battery terminal when installing? If you do not do this and unplug the MAF sensor you will throw a code until you disconnect the negative terminal, wait 15-30 seconds, and then re connect it and start the truck. See this happen a lot. :P Hope this fixes the problem!
If that does not, I would go as far as to say you accidentally broke or damaged the MAF sensor when installing the new CAI. That is not un common I also see that a lot with people putting in new intakes.
