Old 05-22-2012, 10:14 PM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Default clicking noise when turning
Took my truck in today for a clicking noise when turning from both wheels. The mechanic clearly heard my concern and swapped both my front tires and rims with a new truck on the lot and the noise went away. So know im waiting on two new chrome clad rims to come in and be replaced under warranty
Old 05-24-2012, 01:18 AM
tonyhawk196's Avatar
tonyhawk196 tonyhawk196 is offline
Vehicle: 2011 Dodge Ram Express
tonyhawk196 is on a distinguished road
usually a "clicking" noise from the front end when turning is a bad CV Joint, but if the tech fixed it with a rim and tire swap then that works too I guess
Old 05-24-2012, 02:41 AM
Rep:2620
clicking noises when turning is usually on front wheel drive vehicles, when CV joints are bad
i believe you have a different issue
Old 05-24-2012, 12:53 PM
mineralram's Avatar
Rep:166
My issue was solved both Rims were replaced under warranty and the clicking is gone.
According to Dodge the clicking sound will start when the Chrome clad covers start to come loose from the rim.
Old 05-26-2012, 04:35 AM
eldorado99 eldorado99 is offline
Vehicle: 2012 RAM
eldorado99 is on a distinguished road
That sounds possible. I remember old Cadillacs from the 80s doing that when their hubcaps got loose.
Old 11-04-2012, 01:19 PM
oemwheelguy oemwheelguy is offline
Vehicle: 2012 Ram 1500
oemwheelguy is on a distinguished road
Clicking could indicate a wheel warranty problem and should be taken to the dealer for replacement. However, in many cases it is not the wheel, but the center cap. First thing I would do is try removing the caps and see if the clicking disappears. If so, re-install the caps and use some lubricant on them. I would also add that the dealer comment that the claddings are coming loose is not correct - in all my years in the industry not one wheel ever had a cladding come loose out of more than 15 million. If a wheel clicks it is likely caused by production tolerances of the wheel and cladding being out of spec - just a nuisance issue.
