Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 07-25-2012, 02:53 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
ATS is only 2100 plus core!
Old 07-25-2012, 05:27 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Never heard of these guys but I found them looking around a couple months ago....
http://www.importperformancetrans.co...sion-4235.html
Or this might be an option...
http://www.black-ridge.com/transmission-controller.htm
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 07-25-2012, 05:39 PM
I push the skinny pedal
Rep:3277
Your only other 'performance' option is the ATS and it's not much better than the SharaDon one. Nobody has been able to build a bullet proof 545RFE, sadly.
Kurtis
Old 07-27-2012, 12:35 AM
2010SCRam 2010SCRam is offline
Vehicle: 2010 Dodge Ram CC 4x4
Color: Mineral Gray
2010SCRam is on a distinguished road
I haven't heard anything from Mark, the service manager, at the dealership yet so I don't know if he made contact with Denny at SharaDon yet or not. I called Andre at Edge Racing Converters and asked him if he could recommend another good 545RFE incase it goes that route. He didn't personally know of one besides SharaDon but gave me the number to a guy he said knows a lot about Dodge's but I got an answering machine when I called and didn't bother to leave a message so I still haven't talked to him. I was
reading on *************** I think it was and saw a guy talking about the ATS 545RFE
but didn't see how it ended up working out for him. I also saw somebody from SharaDon,
I assume Denny, post under the thread claiming ATS's tranny looked like a SharaDon
stage II. My SharaDon stage III overheated when new, got rebuilt and had the Edge torque converter replaced only to overheat right after I got it back. Had a dent in the transmission pan pounded out that was supposedly right at the pickup tube but it still acted funny. Flow tested the trans cooler and it flowed free. Finally had the solenoid pack
and filters replaced and it worked again but quickly overheated on a moderate 30 drive. I'm thinking that whatever is causing it to overheat is causing the other components to fail and or not work right but why is it overheating! Sorry it's late and I'm rambling cause I'm again unable to sleep thinking about my 2010 truck with 7k miles that's always
broken.
Old 08-02-2012, 10:22 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
I would go with ATS for sure.
Find a installler they will warranty the work from,and get it done.
I would also call Chris at Circle-D and get a nice pro series 2600 stall.
The lower stall will help with heat.
The 4g cooling is a mess.
I would also make sure you are running a 180 stat,and if you dont have a efan get a 295 Flexalight setup for your truck.
I think the biggest problem is going to be heat with your setup.
I run a #295 fan and triple disc 3000 stall from Cirle-D and I tow in the city 18,000 pds the other day,in hot weather.
Temp are way below stock.
Give me a shout if you want.403-617-8733.Grant.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 08-02-2012, 10:57 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^FYI all 4th gens have an electric fan stock.
Sean
Old 08-03-2012, 08:31 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
Might be way off base here, but isn't there a thermostat for the transmission that allows trans fluid to be pumped to the cooler after the trans is warmed up? I don't even know where that is, but if it were inside the transmission and you flow checked the cooler separately, it could still be stuck closed and cause overheating by not allowing the fluid to be pumped out to the cooler. Just an idea.
Old 08-03-2012, 08:45 AM
snrusnak's Avatar
Rep:1385
Yes, I think. I've not physically taken mine apart and seen it, but looking at the blow ups in the service manual it shows a tstat for the transmssion cooling system. IIRC it's at one of the inlets to the cooler.
Sean
Old 08-03-2012, 10:46 AM
Color: Mineral Gray
Rep:72
I have a 2010.
When i changed out my stock cooling system to get rid of my clutch fan,I noticed it had a electric fan thanks.
What I was trying to tell buddy was the stock setup is a pos,especially for a performance motor.
Next time you want to see some hot tranny temps just let it idle on a hot day and watch your tranny temps go up on your evic.
3:92 gears.
Old 08-03-2012, 11:50 AM
snrusnak's Avatar
Rep:1385
^What did you change to?
I haven't had any issues with my setup. Removed clutch fan, adjust efan settings to turn on at ~203 deg F and shut off at ~196 deg F. Also a 180 deg F tstat(although I tested it and it doesn't crack open until nearly 190 deg F). Engine temps are normally around 190-195 even in 100 deg F heat. If I sit at a light for a minute or two it'll rise a few degrees. If I sit for a long time it'll get up to where the efan kicks on and cool to where it shuts off.
Transmission temps aren't any different from stock that I've noticed. Usually around 140-150 deg F. On hot days sitting still it'll get as high as 180-190 deg F max and then cool once moving. I also have a 2800 rpm stall converter. Nothing you can do about hot temps sitting still idling, especially the transmission. Even with a fan it's still going to keep creeping up.
I've heard the v6 fan is better than the stock fan. From all the research I've done it is IDENTICAL except for the shroud. I would assume with the better shroud it'd cool better, just not sure how much better. Is it worth the ~$120 for the swap? Probably....and I'll probably do it one day.
We did 2,600 miles in the truck avg about 75mph from FL to TN then to AR and back to FL, with about 1,000-1,500 lb in the truck and even through the mountains and everything never had any cooling issues. It was also 100+ deg F the whole trip.
EDIT: Just saw you said you had a different fan. So it was an aftermarket install, correct? Didn't just bolt right up? Also saw you tow a lot of weight, so I think we are comparing apples to oranges lol, no way I could ever tow 18,000 lb with my truck. How do you figure you're towing 18,000 lbs with a ram 1500 anyway...?
Sean
