Old 05-23-2012, 09:43 AM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Default Upper control arm tire rub
Hi guys,
So I have had this leveling kit and tire combo on for a few weeks now and love the set up, though since day one, it has rubbed a bit at full lock. I assumed it was in the fender but I decided to investigate some more... What I found was it was touching anywhere in the fender, where it was hitting though was in the upper control arm! Even with the wheels straight there is NO room between the tire and control arm.
My question being here, how safe would it be to install 1/4 inch spacer on this truck?
Tires are 305/55/20
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 05-23-2012, 10:03 AM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
1/4" spacers is what I had to run on my tires also due to the same reason, never had a issue with them, ALOT of guys here run that spacer for same reason, just make sure you get hub centric ones or the hub centric rings to help line everything up, if not just take your time lining it all up and your fine. I would get it done asap, if you run low air pressure on your tire it will rub even more
Old 05-23-2012, 01:39 PM
Rep:156
what is the difference between the two? which is better? Just wanna make sure everything is safe still
