Engine and Transmission adaptives - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 05-24-2012, 01:56 AM
bighemi04's Avatar
Vehicle: 2017 1500 Laramie
Rep:623
Default Engine and Transmission adaptives
My shop did right and fixed my trans free of charge. They also reset all adaptive on engine and trans. From a performance standpoint is this an opportunity to improve things such as throttle response and shift firmness? If I drive normally what will be the affects?
Old 05-24-2012, 04:49 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
That's awesome. It's nice to see businesses stand behind their work.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 05-24-2012, 04:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It will pretty much "adapt" to the same end point. If you drive like a "grandma" it will learn to shift at earlier rpms, etc. If you drive like a mad man it'll learn to shift at higher rpms, etc.
It will always do this though so if you drive like a "grandma" for a month and it learns that, then for the next month drive like a mad man it will learn that...
Sean
Old 05-25-2012, 12:55 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
you wanna drive it like you stole it...the adaptives will be more aggressive...
Old 05-25-2012, 12:56 AM
chefred112's Avatar
Rep:656
if I know I'm goin to the track next weekend, I will reset the pcm and gas pedal and drive it hard all week leading up to the next weekend...
Old 05-25-2012, 01:54 AM
bighemi04's Avatar
Rep:623
It ws my first time using this shop. They are a race shop as well, I dropped my truck off to a Porsche rally car and a tubbed out Stingray on the racks so i figured my truck was in good hands. You can tell they were really embarassed about the whole situation and were more than happy to do what they had to do to make it right, which made it easy on me because i wasnt going to pay them anyways.
Old 05-25-2012, 09:23 AM
chefred112's Avatar
Rep:656
what work was done to it?
Old 05-25-2012, 11:44 AM
bighemi04's Avatar
Rep:623
My rear trans seal was going out which was throwing fluid on my evap hose which cause it to swell and crack. So they did my rear seal, trans service, evap system, coolant flush and fill, and rear diff service. And it was after the trans service that i started having the trans problems
Old 05-27-2012, 05:24 PM
chefred112's Avatar
Rep:656
what trans problems?
Old 05-27-2012, 11:02 PM
bighemi04's Avatar
Rep:623
My rear seal started going out so i took it and and had them replace the seal and do the fluid and filters at the same time. I get it back and two days after that my check engine light comes on, p0876 , and it dies out at a stop light or two on the way home. Concerned about it but chalked it up to bad gas. Well I get in it today and drive to the gas station with no problems. Drive it home and it slams into first gear going over a bump. come to the next stop sign and it goes into limp mode, pull over turn it off and restart it and it has no problem shifting.
