Old 05-24-2012, 07:46 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
Default towing ?'s
looking for tips? have to tow an 8300 pound travel trailer , about a 2 hr so drive.truck is rated to tow 8900, i have an airlift 1000 rear air springs . have all the proper weight distibution bars and stuff . trailer has electric brakes.so few questions i have are what tire psi to run? what about the air shocks? should i use tow haul or just the manual shift it, what would be good setting for the trailer brake. i have the factory tow package with the hitch brake and cooler.and load range d tires. asked this on another forum and was told to go rent a diesel, which im not for a one time deal,and drive 4 hours to rent one and then do it again to drop it off. dropping this off in a park and leaving again so its not a regular basis type of thig, one time deal. its a decent and fairly flat road, my truck is fairly new so brakes are perfect and not a concern.just lookin for tips not judgment.
2011 Hemi RCSB Sport 4x4
Old 05-24-2012, 08:27 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
Pump the tires up to the load PSI in the door. This will help "stiffen" the ride and reduce the trailer sway. As to the airlift I'd just give them (airlift) a call and see what they recommend. You should be fine, I towed 7000 from Orlando to Birmingham via Atlanta (12 hours with the trailer) in terrible conditions with no issue and managed some really good mpg's due to reduced speeds. Utilize the tow/haul setting on the truck, and I'd recommend driving to the trailer (or atleast 15 minutes of driving) with it in this mode so the transmission gets "dialed in". Since the tranny has an adaptive shift "learning" feature you will likely have some quirky shifts after you drop it off - this is normal and it is just readjusting to not having the extra weight. You'll definately feel the trailer back there too, so keep in mind that our motors have a pretty high RPM for the peak HP/TQ...to get it moving you'll probably have to give it some throttle. Finally, make sure you have a full tank of fuel...don't expect amazing mpg's with that behind you.
Old 05-24-2012, 09:09 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I tow a Travel Trailer thats weigh's in the neighborhood of 10K with my 08, I use the Reese dual sway control system and never have had any issue's what so ever. Truck has all the trailer package equipment on it. Now I don't do this everyday but at least once a year sense I travel for work with my trailer. inflate your tires to max PSI, you will be fine. Do the obvious and check all fluids and take some with you.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 05-25-2012, 04:03 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
Some people say use tow haul mode some people say don't I always do I like the fact that when there is a slow down on interstate or in town when u apply the brake in tow haul mode it will drop you down a gear and use engine and transmission to help slow you down. I don't feel this when I just use manual mode. plus you its time to get back on throttle there is no hard drop in gear because you are already there.. in fact I leave tomorrow morning at 6am with my Pop up camper to get away for the weekend, and I will be going through the mountains so tow haul will be defiantly engaged.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 05-25-2012, 08:50 PM
Vehicle: 2011 Ram
Rep:141
thanks for all the info, i hope my air bags show up before my trip
Old 05-26-2012, 03:07 AM
Rescue1 Rescue1 is offline
Rep:64
Rescue1 will become famous soon enough
I love Diesel motors, don't get me wrong, but that comment you received from elsewhere is just ignorant. Now if you had to tow that load everyday, yes I think a Diesel truck is the way to go, but for many of us we need a truck for various things, occasional towing/Hauling being one of them. The HEMI does a fine job as an all around truck. And I bet some of these nuts that have a Diesel only tow a few times a year, a waste at the high Diesel fuel prices if you ask me...LOL..
Good luck either way, I would like to hear how the trip went..
Old 05-28-2012, 06:10 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Hello Newfiebullet,
I'm running close to 6500 pounds with my 21 ft. Travel Trailer and regularly take it camping to the mountains. My 2011 Outdoorsman comes with 17" Tires and I inflate them to a few pounds shy of maximum - max. is 50 pounds in this case so I run around 48 pounds. I've also installed Firestone Airbags inside the coil springs and they work great.
With your Airlift system and Weight Distribution Hitch you should have no problem hauling this load. I do use my Tow/Haul Mode pretty much the entire trip as I've read that this is the way to go if you want your tranny to last. I would also recommend you use at least the mid-grade Octane (89) whenever you are towing as it does make a difference. When I'm not towing I use the lower 87 grade mixed with 89. The HEMI has plenty of power but take it easy and do expect to feel that trailer behind you!
Happy towing.
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 05-28-2012, 07:27 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Alot of good advice here.
Old 05-29-2012, 12:21 AM
Vehicle: 2011 Ram
Rep:141
thanks so much for the info just wat i needed, especially the guys that do this on a reg basis, only last questions is what is a good ballpark on the trailer brake? again thanks so much.
Old 05-29-2012, 01:54 AM
79time 79time is offline
Vehicle: 2011 Ram 1500
79time is on a distinguished road
I would start with a 5 and make make a couple of test in the neighborhood. You will be able to tell if it needs to be increased or decreased.
