Old 05-24-2012, 09:04 PM
ph34r3d ph34r3d is offline
Vehicle: 2004 Dodge RAM 2500HD
Color: Charcoal Gray
ph34r3d is on a distinguished road
Default Hard shifting with nv4500 trans
I just recently purchased a 2004 Ram 2500HD, 5.7 Hemi , 5 speed (nv4500) transmission. From time to time I have a hard time putting the truck into 1st gear and reverse when I am at a complete stop. I just about have to slam it into 1st and reverse is even worse at times. If I am rolling slowly, I can sometimes shift it into 1st pretty smooth. I am not sure if its the clutch that is the problem or if it could be the pilot bearing? The truck only have 78500 or so miles on it.
I am just trying to get an idea of what this might be, I am new to dodge's.
Old 05-25-2012, 11:09 PM
*update*
I checked the fluid in the trans and it was not low. The fluid did seem to be quite "bubbly" and did kind of smell burnt?
Old 07-20-2012, 08:16 PM
calinb calinb is offline
Vehicle: 2004 1500 Ram ST
calinb is on a distinguished road
I have a 2004 Ram 1500 with the 3.7l and NV3500. I first noticed intermittent notchy shifting and difficulty getting it into gear, as you describe, at around 50,000 miles. The problem would come and go and it now has 113,000 miles on it. I just pulled the transmission today and what's left of the pilot bearing had seized and galled the input shaft. I'm trying to figure out if that shaft can be replaced via the front bell housing cover. The clutch still had some life left in it. What a bummer of a failure mode. Did they forget to lube this bearing in assembly?
Old 12-26-2012, 01:10 PM
03Ram2500 03Ram2500 is offline
Vehicle: 2003 Dodge Ram 2500
Color: Mineral Gray
Rep:21
03Ram2500 is on a distinguished road
I have the same set-up and the difficulty from 1st and going into reverse is the same. When the truck had around 50,000 the pilot bearing went, and the same shifting exsisted after they replaced they pilot bearing and the clutch. I now have over 120,000 and it has not changed or became worse.
Old 12-26-2012, 01:25 PM
Rep:1884
Sounds a lot like a clutch that isn't fully releasing to me.
