Hypertech Speedometer Calibrator--Works great on 2011/2012! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Product Reviews
Product Reviews Have you found a great product, or a really bad one and you just need to tell someone about it! Post up a review for the benefit of all!
Old 05-26-2012, 12:12 PM
WarBaby's Avatar
WarBaby WarBaby is offline
Vehicle: 2017 Ram 1500 Express RCSB
Rep:43
WarBaby is on a distinguished road
Thumbs up Hypertech Speedometer Calibrator--Works great on 2011/2012!
For street 'n strip purposes, I changed the factory tires on my 2011 Ram ST RCSB from the stock 265/70R17's to new 275/55R17's on the front staggared with new 305/45R18's on the rear. Both of the new tire sizes are within 1/10" in diameter at slightly under 29" (stock diameter was 31.6"). Obviously, I needed to correct my ECU for the new tire height.
A call to my dealer revealed that they could flash the ECU for about $95. I thought damnnn, that ain't cheap for 5 minutes work. I remembered that the Hypertech Speedo Calibrator was mentioned in a thread on this forum and one of the posters said it worked on 2011 models...! A quick visit to Hypertech's web site confirmed that information and I ordered one. It cost twice what the dealer wanted to flash the ECU but at least I would own it. It can read and erase codes, change gear ratios, calibrate the speedometer, and return to factory settings anytime. Possible tire sizes range from 22.5" to 44" in .25" increments. It's not a real tuner but it's as close as I can get for now.
The package arrived by UPS and included a USB cable, an OBD port cable, a CD that contains both instructions and an installable computer application for updating the Hypertech firmware online. I installed the app, ran it, and was promptly informed that I had the latest firmware. Cool! I then read the CD instructions which specified that no electrical device should be allowed to operate (draw current from the battery) while the Hypertech unit was connected to the OBD II port (apparently it is VERY voltage sensitive). I pulled the fuse for the sat radio, closed the door, fastened the seat belt, turned the key to "On" and connected the Hypertech to the OBD port under the dash. The unit's display came alive with checks and easy instructions. It said there was one DTC (data trouble code) which I looked up at an online OBD II website. It was..."Failure to communicate with radio". Well, of course, I just disconnected the radio fuse! More coolness--it works!
Happy that it all seemed to be connecting properly, I followed the simple screen prompts and entered my new tire size which was flash-written to the ECU without any issues. I am impressed that the unit does what Hypertech claims it does.
I rate it A+.
If it's not broken, fix it till it is!
Old 07-30-2012, 02:57 PM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
What unit of measure do you enter to calibrate the tire sizes ?
Old 07-30-2012, 03:08 PM
WarBaby's Avatar
Rep:43
As mentioned above, "Possible tire sizes range from 22.5" to 44" in .25" increments".
Old 07-30-2012, 10:10 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
Nice post man!!! This is a great find for somebody who goes to the track a lot and changes their rear tires out to DRs then back to their daily drivers setup!! Instead of having to go to the dealer each time, and paying 95 dollars... Or just dealing with the speedo being different! I am going to have to invest in one of these for sure!
Old 07-30-2012, 10:17 PM
WarBaby's Avatar
Rep:43
Originally Posted by Jchaney579 View Post
Nice post man!!!
Many thanks to you.
Old 01-30-2013, 12:16 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Thanks for the great post WarBaby!. I will probably be changing my factory tire size (275-70-17) as it's an odd market size and limited to only a few manufacturers. This Hypertech Calibrator will be great for re-calibrating to a new tire size.
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 01-30-2013, 03:20 PM
WarBaby's Avatar
Rep:43
Glad my post was helpful.
Old 03-22-2013, 03:34 PM
06Stang's Avatar
06Stang 06Stang is offline
Vehicle: 2014 RAM 1500 Sport
Color: Granite
Rep:40
06Stang is on a distinguished road
Any of them work on more than one vehicle at a time?
Chrysler Jeep Accessories Tech
