Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 05-27-2012, 10:53 PM
FSUNole17 FSUNole17 is offline
Vehicle: 2008 Dodge Ram 1500 Sport
FSUNole17 is on a distinguished road
Default Any tricks or tips to get the clutch fan off?
Installing efans soon and wanted to see if anyone had any tips or tricks to get that mother off. Thanks!
Old 06-17-2012, 06:55 PM
Paulren16 Paulren16 is offline
Vehicle: 2001 Dodge Ram SLT
Paulren16 is on a distinguished road
I just replaced mine last week, if you (or a friend) have access to an air hammer, you can (VERY CAREFULLY) tickle it with a flat tip and it will usually break loose fairly easily. I stress CAREFUL, as I've been a tech for 25 yrs, the last 18 with Caterpillar. That's how I had to get mine off. Hope this helps.
Old 06-17-2012, 07:02 PM
PS: Make sure you're turning that clutch the correct direction, My fan is reverse rotation of the engine, due to the serpentine belt. The clutch threads so that engine rotation is in the tightening direction. Therefore, mine has right hand threads. Usually, if the fan is in rotation, it will have left hand threads. I hope this helps, Good Luck!
Old 07-09-2012, 09:44 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
When I did it I made a spanner wrench that has bolts that fit into the fan. Then I used that to hold the fan in place and a large wrench to loosen up the nut holding the fan on.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
