Old 05-28-2012, 05:20 PM
Ce2700 Ce2700 is offline
Vehicle: 2004 dodge ram 1500 4.7
Trim Level: St quad cab
Ce2700 is on a distinguished road
Default 04 ram 1500 known issues?
Just wondering what the known issues are on this year truck? It is a 04 st quad cab with 72 k on it.
Thanks
Old 05-28-2012, 06:50 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
just typical morning valve adjuster knocks and minor maintenance issue like leaks at the radiator or maybe non depending the abuse of the vehicle.
Old 01-13-2013, 10:20 AM
hobbithead hobbithead is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: Base
hobbithead is on a distinguished road
Blew a head gasket on my 2004, 150,000 miles. Head gaskets are a problem with these engines. Sludge buildup is also bad. I used STP ever since it was new, and my insides were clean as a whistle. I would highly recommend STP.
Old 01-13-2013, 11:07 AM
bighemi04's Avatar
Rep:623
I went through 2 wheel hubs, a power steering cooler, an idler pulley, transmission solenoid pack in 113000 miles in my old 04.
Old 01-13-2013, 11:22 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I owned a 4.7 before my current Hemi and did a lot of research and reading and I personally have never heard of any issues concerning head gaskets with these engines. The only real problem I have heard of is the sludge issue and that really seems to depend on how the engine was maintained, specifically the oil change frequency. Without pulling a valve cover to look, it's hard to know whether this has been properly maintained on a used vehicle so all you can really do is maintain it from this point forward. Consider running some Seafoam through the oil (only for a couple hundred miles before you change it), maybe switching to synthetic oil, and change the PCV valve if you don't know when it was last changed.
Old 01-13-2013, 11:36 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I believe the 04 and 05's are very similar. In 180,000 miles I've replaced a u-joint,a ball joint and I put Rancho 9000 shocks when it was new, still good. My only complaint is a front end clunk at slow speed.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 01-14-2013, 05:52 PM
jmiller2308 jmiller2308 is offline
Vehicle: 2011
Color: Green
jmiller2308 is on a distinguished road
At around 50K miles the shop I brought my truck to to make it ready for towing told me it had blown the clutch packs and was eating the pumpkin. They called around to try to find a salvage axle and were having a hard time because apparently this happened a lot.
Old 01-14-2013, 05:53 PM
Vehicle: 2011
Color: Green
I forgot to mention this was with the 5.7 hemi and the rear end that was unique to that power package.
