Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 3.9L V6 Specifc Topics
Old 05-28-2012, 09:35 PM
JB10 JB10 is offline
Vehicle: 2001 dodge ram
Trim Level: 1500 2x4 v6 magnum
Color: blue
JB10 is on a distinguished road
Default Stalls while i press the gas
I have a 2001 dodge ram 1500 2x4..The truck drives fine for the most part except while i am at a red light and i press the gas the truck stalls sometimes but it always drops in rpms like its going to stall. It also does this in reverse sometimes. I have cleaned the IAC in and out. Any other ideas would be great. Thank you.
Old 05-28-2012, 09:38 PM
Color: blue
I also forgot to mention that when idling it is low around 4-500 rpms
Old 05-28-2012, 11:27 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Will it rev at all as in higher rpms? If not it could be a plugged cat. A quick check is remove the upstream 02 sensors 1 at a time and see if behavior changes when you run it.
Old 05-29-2012, 09:21 AM
Color: blue
It wont when I am in neutral or park but when im driving and it doesnt stall then it does get up in rpms i will pull out a sensor and post if it has any effect thank you.
Old 05-29-2012, 10:27 AM
Color: blue
It had the same problem when the sensors were pulled. Is the next step removing the cat and unclogging it or do i need a brand new one?
Old 05-29-2012, 12:19 PM
namretsud's Avatar
Color: Inferno Red
Rep:185
Same problem with the sensors out means your problem is upstream from the cat as when you pull the sensors out it relieves the pressure on a plugged cat. You may want to run some seafoam in you tank (most auto part stores carry this) and it could be one of many sensors. Have you had a code reader hooked up to it as there could be something there?
Old 05-29-2012, 12:25 PM
Color: blue
I actually have seafoam but i am a little sketchy about using it. But the check engine light did come on before for about 3 hrs then it went away and has not been back. And when i took it to get a code the computer did not register one. So I am out of luck there. I may try the seafoam and see where that gets me. The help is much appreciated.
Old 05-29-2012, 06:39 PM
Color: blue
Seafoam worked like a charm... I was a little worried about the proper way of putting it in but I obviously got it right lol. hopefully the problem doesnt emerge again anytime soon. Thank you for the help.
Old 05-30-2012, 12:09 AM
namretsud's Avatar
Color: Inferno Red
Rep:185
For the next few fillup you may want to add seafoam every other tank to get the most out of it. You would be surprised what can build up over time and the seafoam seems to do a good job of cleaning out the carbon deposits and buildups.
Old 06-03-2012, 09:10 PM
Color: blue
It has started doing it again...and now i have a check engine with a code p0455 evap emission system leak(large)... I have checked all the hoses and they all seem to be good. How would i go about doing a homemade smoke test? And the seafoam worked could it be I just have that much crap in there? Or maybe the wrong type of hoses?
