Old 05-29-2012, 01:47 AM
Ram2300 Ram2300 is offline
Vehicle: 2011 dodge ram 1500
Ram2300 is on a distinguished road
Default Is it better to get an efan or a dual electric fan?
A few people told me that a dual electric fan works better on the engine compared to a single electric fan (Efan) because the duals cover the whole radiator versus the single only covers the middle part of the fan? Any suggestions on what I should do on the modification?
Old 05-29-2012, 09:23 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
As long as it's shrouded properly a single fan works just as well as a dual, and maybe even better as it probably covers more of the radiator. The benefit of a dual fan setup is that if one fails you have the other and won't overheat. I'd go with a single as it's typically about half the cost...
Also, your truck has an electric fan(in addition to the mechanical clutch fan) stock that provides plenty of cooling.
Sean
Old 05-30-2012, 11:49 PM
Ram Pants's Avatar
Ram Pants Ram Pants is offline
Ram Pants is on a distinguished road
Agreed with what snrusnak said. The big factor that oem's used to decide dual vs. single fan was radiator shape. Most dual fans are used on rectangular shaped radiators. Our ram radiator is fairly square which can be adequately cooled with a single large diameter fan. Dual fans would still leave dead spots they would need to be offset [oo] vs. [O]. My crude diagram prevents me from showing how the dual fans need to be offset from each other which would also leave you with coverage issues. The other driver for large single is cost and simplicity for the electrical wiring and load.
Old 05-31-2012, 11:19 PM
So Efan is the way to go then? How much is the Efan?
Old 05-31-2012, 11:24 PM
snrusnak's Avatar
Rep:1385
Like I said above:
Since you have a 2011, there is no tuning available. So it wouldn't be wise to remove the stock clutch fan and rely on an electric fan that you can't control(unless you setup an aftermarket controller).
Sean
Old 05-31-2012, 11:55 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Why mess with it anyway unless your truck runs hot...then the dealer needs to be involved.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 06-01-2012, 12:06 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
efan prices vary..I run a pick n pull taurus efan..$25.00... i think new ones ar $180+
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 06-03-2012, 02:13 AM
The reason why I ask about the Efan or dual fan is because I was told that the engine runs better, less strain on the cam and pullies, better rpm's and gives u like 1-2 mpg better, somethin like 5-10 hp better and like 5 tq but I have never done it before so I rather have some opinions on it before I waste my money or what not.
Old 06-03-2012, 10:36 AM
snrusnak's Avatar
Rep:1385
Like I said above:
Reread the posts above man. You already have an electric fan on your truck.
Sean
Old 06-03-2012, 11:32 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Install a 180 tstat and ditch your clutch fan, you don't need it...especially with a 180 tstat. You will never learn anthing unless you try it first hand. Auto tech is where it is today because of people like you who experimented with what they beleived may benifit performance. Take the plunge and enjoy the experience. These guys that recomend not to are stuck in first gear...no offense meant.
