Place your Ad Here!
Old 05-29-2012, 01:40 PM
BigHornRam2006's Avatar
BigHornRam2006 BigHornRam2006 is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Big Horn Edition
Color: Patriot Blue Metallic
BigHornRam2006 is on a distinguished road
Default Wheel Spacers
I came across wheel spacers that are 1.5 inch thick 5x5.5. What are the pros and cons with these wheel spacers? I want to do this so I can keep my factory wheels. Please help me out.
I want to put 35x12.50x20 Nitto Trail Grapplers on my 06 1500 but I would have to get aftermarket wheels just to clear the control arms. I don't want to do that unless I absolutely have to. With my factory 275/60/20 Good-for-a-year tires I have maybe a half inch in between the tire and control arms. I have my new front struts with my 2.5 inch level lift installed.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 05-30-2012, 03:50 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Who makes them? Are they Hub centric? Do they have pressed in studs?
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 05-30-2012, 10:18 AM
To be honest I don't know who makes them, I know that throws the red flag. They are listed on ebay and here is the link. I cannot find them anywhere else.
http://www.ebay.com/itm/4-Dodge-Wheel-Spacers-Adapters-5x5-5-bolt-pattern-1-5-inch-thick-/290701094654?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2006%7CMake%3ADodge%7CModel%3ARam+150 0&hash=item43af22aefe&vxp=mtr
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 05-30-2012, 12:15 PM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
They have everything listed the same as the some of the best out there, BUT I think I would spend the extra 80ish to go with one I trust, motosport-tech etc just to be on safe side. The pros and cons, well the only pro I cant think of is youll be able to fit a wider range of tire/rim sizes, other than that nothing. Cons, possibly wear out front end components quicker, ( so will larger rims/tires etc without spacers, incorrect installment of lifts etc) , possible total failure of studs(not likely).
IF I was you, I would figure the exact amount of spacer you will need, custom order spacer for that size and either cut existing studs or buy new studs length I needed, why you ask? To simply put less stress on front end
Old 05-30-2012, 12:16 PM
Color: grey
Rep:15
Also just scene those spacers are NOT hub/wheel centric, I would not buy any adapter that wasnt, thats just me
Old 05-30-2012, 12:28 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I don't like those also remember it adds another set of lugs you have to keep tight.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 06-02-2012, 02:51 AM
Hootie7159 Hootie7159 is offline
Vehicle: 2010 ram 1500 quad cab 4x4
Trim Level: Slt
Color: light silver
Rep:13
Hootie7159 is on a distinguished road
If you go anything less that 1.75" spacers you'll have to trim the stock lugs to fit the rim onto the spacers....the Motorsport ones are good...as well as wheeladapter.com....and +1 on getting the hubcentric ones...just be wary of cheaply priced eBay spacers...you'll never know what kind of quality your buying....AND...if you looking for wheel spacers I have a barely used set FS..they are 1.75" hubcentric from wheeladapter.com..pm me if your interested...
Old 06-02-2012, 04:21 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:80
Unless there are pocket reliefs on the back side of the wheel like most wheels have. Most cast wheels have a pocket (gap between studs) relief that the stock studs will fit in.
