5" RCX & 3" PA - biggest tire? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-29-2012, 07:38 PM
JohnJr30236 JohnJr30236 is offline
Vehicle: 2004 Dodge Ram
Trim Level: QuadCab SLT Off-Road
Color: Dark Blue
JohnJr30236 is on a distinguished road
Default 5" RCX & 3" PA - biggest tire?
I have a body lift already with 315/70R17's and want to get a suspension lift soon. With 8 inches total what can I run? I read thru the stickies, one said 6" will fit 37's, and in the other no one had quite the same setup.
2014 Ram 1500 Black Express RCSB 3.6L 8-spd
Old 05-29-2012, 07:54 PM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
With a 6" lift 35's are usually perfect in most peoples opinion but yes in most cases you can run 37's without rubbing issues. With a 5" suspension and a 3" body you shouldnt have a problem running 38's, but i wouldnt go any bigger IMO. If it were me Id throw 37's on it and call it good!
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
Old 05-30-2012, 12:18 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
I'm gonna say you could do 38s. Just watch your wheel offset and tire width.
[CENTER][SIGPIC][/SIGPIC]
Old 06-02-2012, 11:56 AM
Color: Dark Blue
I have the stock 17's with 2 inch spacers on it now. I can't go wider than a 12.50 or 13.50 without a wider wheel, and even that's pushing it since they're only 8 inches wide. I seen a 2500 with 8 inch lift running 39.5x12.50...how much taller is a 2500 vs a 1500?
Old 06-02-2012, 08:12 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
2500s are 3-4" taller than 1500s stock.
I'm with candy, 38s should work just fine. That stock rim might come into play tho
2011 Big Horn 4x4 -SnowWhite-
Old 06-05-2012, 04:26 PM
Color: Dark Blue
So it safe to say a 2500 with a 4-5 inch lift would be comparable size-wise to my 1500 with 8 inches of lift?
Old 06-05-2012, 05:44 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
id check the gearing before i went with a 38" or 37" tire. other than that id say candy is right
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 06-06-2012, 04:10 AM
SS4Luck's Avatar
Rep:310
In theory I guess yes. I would have to put them next to eachother to give you a yes or a no.
I believe the HD trucks have larger wheel wells as well which would aid in the larger tires as well.
Old 06-06-2012, 05:11 PM
Color: Dark Blue
Hmm i always thought the fenders and what not were the same....but any way it gives me a rough estimate for comparison
