Old 06-30-2011, 11:23 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
Default are 1500 and 2500 suspension parts interchangeable?
i have a 95 ram 1500 4x4, im going to be replacing the suspension soon here and im wondering if i can get 2500 leafs, coils, and shocks to put on my 1500. will this work?
Old 07-01-2011, 02:28 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Not exactly sure, why do you want to bump up to the heavier suspension? Got a particular plan for the truck?
Old 07-01-2011, 06:35 AM
Color: inferno red
well i figured why not get the beefier suspension if im going to replace it all. plus it will give the truck a little more lift, and i could haul and tow more.
Old 07-01-2011, 08:02 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Beefier means rougher, and by putting the HD suspension on you can only make your truck handle the weight better, legally you cannot change your tow rating. It is what it is. You could be looking at alot of problems if your towing over weight
Old 07-01-2011, 05:36 PM
Color: inferno red
i didnt ask if it would make my ride rougher or not. i asked if it was possible? can i put the 2500 suspension parts on my 1500 or not?
Old 07-01-2011, 05:39 PM
That's a good question. You can swap suspension but you'll need all the brackets, shock pads, springs, U-bolts, etc...to make it work.
Old 07-01-2011, 05:44 PM
Rep:2657
I believe you would have to fabricate some leaf spring mounts on the frame
but, both models MAY use the same frame & there may be markings for the location
Old 07-01-2011, 08:01 PM
Color: inferno red
thank you! thats what i needed to know!
Old 09-19-2011, 11:37 AM
MBCJim MBCJim is offline
Vehicle: 1999 Dodge Ram
Color: Green
MBCJim is on a distinguished road
Were you able to swao in 2500 suspension equipment? Been thinking about doing it myself.
Old 09-19-2011, 09:14 PM
Color: inferno red
i am actually doing it either next weekend or the weekend after. i have all the 2500 parts i need just need to do it. but i do know its possible! a guy at my local autozone has a 94 1500 with 2500 suspension on it. he told me everything off 2500 and 3500 will bolt right up to a 1500 exept for the rear leaf springs. but all you have to do is bend the mounting ears out a little to fit in the bigger 3 inch wide leafs. im swaping everything while i have it torn apart so its probly guna turn into a week long project. hers what im doing,
2500 shocks and struts
2500 coil springs
2500 leafs
wheel bearings
ball joints
u joints
tie rod ends
and all other bushings up front.
ill update everyone after im all done. hopefully i dont run into any major problems....
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-02-2011 11:38 PM
Oh man, life threw me a curveball.. 1500 or 2500? chrismeyers2k1 2011 Dodge Ram Forum 17 03-13-2011 01:30 AM
2500 to 1500 axle swap bikequad4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-22-2010 12:52 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
1500 to 2500 rustyolred Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 02-05-2010 06:08 PM
