Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 05-30-2012, 12:43 AM
moparornocar72's Avatar
Rep:630
Default which tires for the track?
What tires and where have ya'll gotten them from.
I am picking up some stock aluminum 17's on thursday, and will be looking into getting some tires for the track.
I have been looking at the following:
275/55/17 general grabber uhp's, through work $143 a piece
nitto nt555,not sure from where can't get them through work
Mickey thompson, not sure what size, again can't get through work.
Should i keep it budget and go general's or go higher? Here's a pic of the rims.
14.268 @ 95 MPH Full Trim
Old 05-30-2012, 01:00 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I would do some 275/40 drag radials for mustangs or trans ams. Lower profile...higher effective gear ratio! Nitto makes an NT05R in that size, Hoosier has one as well as M/T. All are around 200 each, and then you can get a cheap 275/40 crap tire to run up front. Air up the fronts to 40+ psi for the weight.
Old 05-30-2012, 10:40 AM
Rep:630
Our supplier is out of stock on the nitto nt05's but they matched the price of the general grabber uhp in the nt555 nittos so i went with 2 of those. 275/40/17 and they will be here this afternoon!
Old 05-30-2012, 12:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
What's your rear gear ratio, 3.55? That's about a 26" tall tire. That should put your effective ratio roughly equivalent to 4.56. A little steep IMO, but I know how much everyone on here loves that magical number
Sean
Old 05-30-2012, 01:28 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Why the nt555 over the nt555r's in regards to track tires vs street?
Old 05-30-2012, 06:59 PM
Rep:630
I have 3.92's and the 555r's r currently out of stock
Old 05-30-2012, 07:27 PM
Color: Satin Orange
Rep:627
Gotcha. Looking forward to see how the 555's work out at the track since its a street tire.
Good luck!
Old 05-30-2012, 07:33 PM
snrusnak's Avatar
Rep:1385
Wow, you're going to have some serious launching power, lol. I'm curious to see how it works out. You'll be nearing 5,000 rpm's in 1:1 gear at the gates. You'll have better gearing, and are spreading the acceleration out over more gears, but add in an additional shift.
Sean
Old 05-30-2012, 08:05 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
are the NT05s out of stock or the NT05R? I'd def go with the NT05R and order them from Discount Tire Direct if you have to.
http://www.nittotire.com/Tire/nt05r
Old 05-30-2012, 08:09 PM
916Timmy's Avatar
Rep:1443
Those 555s arent drag tires, just regular street tires
