Old 05-30-2012, 05:56 PM
Fraser Fraser is offline
Vehicle: 1996 dodge ram
Trim Level: laramie
Color: green
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Fraser is on a distinguished road
Default engine swap question
hello got a quick yes or no question. I have a 1996 dodge ram 2wd with a 5.2, cant come across any 5.2's out of a dodge in my area worth buying but i can get a 1995 Jeep cherokee 5.2 318 engine will everything line up fine?
Old 05-30-2012, 10:10 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Block and heads will be the same as the ram. There may be some differance with sensors or cam not that cam will make a diffence to the truck. Just don't throw away the old eng before your done. Its best if you can look at both of them side by side to see what needs to be swaped from one to the other but as far as block and heads there same.
Old 06-01-2012, 12:46 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Cam is same too. The sensor connectors changed with OBD II in '96, but just use the ones for your truck.
