Old 05-30-2012, 10:58 PM
Blakew76 Blakew76 is offline
Vehicle: 2007 Dodge Ram
Color: Blue
Blakew76 is on a distinguished road
Default sqealing brakes
Hi, I've had my 2007 Ram 1500 for a few weeks now. The brakes squeal just before comming to a stop at low speeds. There's lots of brake pad thickness remaining, & it doesn't pull or vibrate at all when slowing down.
Thanks...
Old 05-30-2012, 11:43 PM
chrisp chrisp is offline
Vehicle: 05 ram
Color: silver
Rep:12
chrisp is on a distinguished road
i have the same damn problem! did it since i got it 2 years ago, i even went through the trouble of taking the pads off and creating a chamfer on the edge of the pads. also mine is intermittent problem. is yours?
Old 05-31-2012, 01:46 AM
Color: Blue
Not everytime I stop, but more often than not. Not sure if spraying brake clean on the rotors & wiping them would help at all or not.
Old 06-01-2012, 12:15 AM
RobK's Avatar
RobK RobK is offline
Vehicle: 2007 Dodge Ram 1500
RobK is on a distinguished road
I also just bought a 2007 yesterday with 23,000 ish miles and I am having the exact same squeak as described above!
Old 06-01-2012, 12:59 AM
I push the skinny pedal
Rep:3308
Hell, with new pads and rotors mine still squeal at low speeds, and I'm not running oem brakes either. You can try different pad material or rotors but may still end up with the squeal regardless. You can try bedding the pads and rotors and see if you just have a polished pad/rotor, basically it's a few 100-0 stops to give the pads a fresh surface.
Kurtis
Old 06-01-2012, 01:27 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Sometimes a small amount of forma gasket type of silicone applied inbetween the piston and the back of the pads will help. That's what the small pack of red stuff that usually comes in the brake kit is for. Some even come with a gasket type pad...or use to anyway.
Old 06-01-2012, 02:07 AM
RAMROD5's Avatar
RAMROD5 RAMROD5 is offline
Vehicle: 2006 Dodge Ram 3500 Dually
Rep:13
RAMROD5 is on a distinguished road
Ceramic pads will squeal as well, theyre a much better pad, but they make some noise....not saying its your problem, but it could be
2006 Ram 3500 Dually, 5.7 hemi.
Old 06-02-2012, 03:00 AM
Color: Blue
I think I'll live with it until the brakes are worn out. No point spending money on different pads/rotors if it'll still squeal. Thanks for the info though! Sounds like a somewhat common issue.
