Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 05-30-2012, 10:05 PM
seanm seanm is offline
Vehicle: 2011 Ram 1500
Color: Green
Rep:21
seanm is on a distinguished road
Default Best product for removing superficial scratches?
So it seems like every time I come out to the parking lot I have a new scratch on my truck. The joys of living on an Army base I suppose.
Anyways what's the recommended product to remove the smaller scratches?
And while I'm at it, what's everyones favorite cleaning supplies for their trucks? Interior, exterior, tires, etc. I just wanted to know what the best out there was.
Old 05-31-2012, 03:52 AM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
I prefer the meguiar's Professional products, most you can find at NAPA stores. There are so many good products out there, and then there is some crap. The other problem is, this question is like asking which oil to use, so many opinions, so little time. Just use what works best for you..For me I clay, glaze(polish) and wax. I use either a good carnauba in the summer(for the deeper look) and a synthetic in the winter for the durability.
As far as scratches go check out meguiar's site. They have a video that shows their scratch X product. It works pretty well for swirl marks and such. Not sure how deep your "Superficial" scratch is, but if your finger nail gets stuck in it you have some work ahead of you to get rid of it. If it's less of a scratch then try the scratch X. I am sure others have some good ideas as well, either way good luck...
Old 05-31-2012, 08:03 AM
dkerr24 dkerr24 is offline
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
I have similar issues with parking at the local Air Force base. I get to work 30 mins early and carefully pick a parking spot that is on a end spot and not near a foot traffic area. Extra 1/4 mile walk to my building, but so far the extra diligence has paid off.
Most of the scratches you are getting are most likely from careless folks walking too close and their backpack zippers are scratching down the side of your truck.
Darin
Old 05-31-2012, 08:17 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'd try polishing compound and if that doesn't work then I'd try rubbing compound. If that doesn't take it out I'd leave it. You can wet sand scratches out but this thins the clear coat. I'd rather have a small scratch in a good paint job than have the paint start peeling in a couple years. JMO.
Sean
Old 05-31-2012, 08:33 AM
testiclops's Avatar
testiclops testiclops is offline
Vehicle: 2010 Ram 1500
testiclops is on a distinguished road
Use polish for surface scratches.
"Please contact the Administrator if your date of birth has changed."
Old 05-31-2012, 09:10 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
lets have a looksie at those scratches...it will definately help someone suggesting a product...
also the rule of thumb is to start with the least aggressive correction method/product first (seems pretty obvious, but you'd be surprised at people that throw an overly aggressive compound on a rotary buffer with a wool pad that only needed a glaze/polish and instilled more scratches/swirls than before their correction).
Old 05-31-2012, 09:32 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
Pictures are good [asking for pictures tends to end threads though].
Do you want to invest in a machine? i.e Dual Action Polisher
Do you want to stick to over the counter polishes/products? There are hundreds of brands that most people don't know about that are significantly better than over the counter options.
Old 06-04-2012, 11:01 AM
Color: Green
Rep:21
Lets see if these help. If they go through.
Old 06-04-2012, 01:43 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
Might be able to clean up the outside part of the scratch in the second pic, but I think the scratch right in the center of it all will need some touch up paint. All the other pics will also need touch up as they all look to be into the primer. You will need a machine, cutting poish and cutting pads in order to fix that. Might be able to clean up a little bit of pic 3, but I think most of it will still be there after the fact.
Old 06-04-2012, 05:16 PM
Rep:912
i pretty much agree with jayincali...but for me, i dont know if id consider the touch up unless it was right down to metal (maybe the primer).
the pics are a little hard to see truthfully, but try and run the back of your nail across the scratch in the second pic...if it catches, its likely not coming out...but it may be able to be hidden. try first with a polish (i've used wolfgang with good results and Klasse with alright results[i think i needed an orange pad on the BMW i corrected instead of the white], but there are other quality products out there like Menzerna, Meguiars etc.) The polish will cut the edge of the scratch a little more so it is less refractive of light, therefore making it less noticable from a distance (youll always see it up close...especially cause you know it is tehre) Alternatively, a qualoty glaze will fill it in...people always forget about the power of a good glaze.
since you asked, and if your using a machine, Id recommend trying a polish over a compound first. if it doesn't come out to your satisfaction with the polish, id hit er with some glaze then seal it...as long as you keep up on topping the wax and take care not to instill more scratches swirls, you'd likely be satisfied.
