Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 05-31-2012, 09:39 PM
Dutch Dodge Dutch Dodge is offline
Dutch Dodge is on a distinguished road
Question High pitch whine while shifting
When I am going on to the highway, driving normally, right before the truck shifts it makes a high pitch whine. It only makes it makes the sounds around the lasts 300 rpm's before it shifts. Next to this I also have another thing that caught my attention, when I leave my truck standing overnight and I start it up it turns over.... small hesitant and it runs.... for both issues it doesn't throw out any codes.... it is a 2010 Truck.... is this normal or am I too anal about things
Old 06-01-2012, 07:24 AM
Vehicle: N/A
Rep:365
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
If the whine is "right before" it shifts, it may actually be at the very start of the shift. Upshifts occur in two phases: the torque phase and the inertia (or speed change) phase. During the torque phase, torque is handed off from the releasing clutch to the applying clutch. Once the torque handoff is completed, the turbine speed drops (which causes the engine speed to drop), which is what most people would notice as "the shift." But the shift actually started before the speed change.
Is this on one particular upshift (like a 3-4), or on all of them? At all speeds / throttles, or only at heavy throttle? Try this: Use your ERS control to limit you to the lower gear (for example, if it's a 3-4 shift where the whine occurs, tap the ERS switches to limit you to "3"). Then see if you get the same whine (at the engine speed where the shift would normally occur). That'll tell you whether it's in the engine alone, or related to the upshift.
