Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-31-2012, 02:27 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Exclamation Compressor issue
Lately I was smelling something I thought was an electrical short, the fumes were overwelming inside the cab, either the ac on or off... Well I smelled it outside the truck and started investigating and after driving today with the ac off and windows down ( since it was cooler out ) I could smell it again. I got back and popped the hood, there was a slight stream of smoke comming off the back of the compressor pulley, since I didnt use the ac It wouldnt be electrical so I assume its smells more like brake pad kinda smell so I assume the compressor clutch is sticking or something? What should I do to save it ? I sprayed some electrical contact cleaner all over the pulley/clutch to clean out any debris, should I spray some dry silicone or WD40 into it? The ac works great, I just dont want to lose it. Thanks.
Mike
Old 05-31-2012, 02:45 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
You might need to take apart the clutch assembly if it's locked up. I wouldn't put WD-40 on it, it may catch on fire then from heat. Try some kind of PTFE type lube.
Old 05-31-2012, 03:02 PM
sonocativo's Avatar
Rep:210
ok thanks.. now to figure out how it comes apart... does have a slight wobble in the pulley I never noticed before?
Mike
Old 05-31-2012, 03:11 PM
ramvan2500's Avatar
Rep:128
A wobble could be a broken bearing or the pulley and clutch have gotten loose, if you rebuild the clutch there are special tools required. I have a service manual to rebuild the compressor clutch if you would like it.
Old 05-31-2012, 03:27 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
I want to rebuild my compressor....is it pretty straight foward on the rebuild? Service manual show exploded diagram?
Old 05-31-2012, 03:29 PM
ramvan2500's Avatar
Rep:128
Yea rebuilding anything is easy if you have to time and in some cases the proper tools. But yes the service manual has nice photos and everything it's very helpful.
Anyone who needs a manual just post your email and I'll send a pdf.
Old 05-31-2012, 04:51 PM
sonocativo's Avatar
Rep:210
Yes, Id like to see if its simple enough to do... maybe just needs a good cleaning? Thanks
Mike
sonocativo's Avatar
Rep:210
And it wont let me give you any more reps yet....geeze
Mike
Old 05-31-2012, 04:57 PM
ramvan2500's Avatar
Rep:128
I guess you give alot of rep... I don't know, maybe you can try later if you like.
Old 06-01-2012, 01:48 PM
sonocativo's Avatar
Rep:210
I will for sure
Mike
