Old 06-19-2012, 02:08 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Looks good!!
After seeing all this stuff I Cant wait to get my lift on
2011 Big Horn 4x4 -SnowWhite-
Old 06-20-2012, 06:16 PM
Moomba Moomba is offline
Vehicle: 2010 dodge ram 1500 4x4 sport
Trim Level: Laramie sport
Moomba is on a distinguished road
Nice set up. Looks great!!.
I have had so many shops here in Houston tell me i can not run what i want with bilsteins set at max which is 20 x 10 fuel hostage with -24 offset and 305/55/20. I have a 2010 1500 4x4 CC.
Is that [bilstein set at max] all you have on this set up??
Did you add a coil spacer in the rear?
I will receive my bilsteins this week and i am about to push the order button on the rims and tires. Any advice is much appreciated.
Old 06-20-2012, 09:30 PM
WhiteKnight's Avatar
WhiteKnight WhiteKnight is offline
Vehicle: 2012 Dodge Ram Crew Cab
Trim Level: Express 4x4
Rep:13
WhiteKnight is on a distinguished road
Just bilstein set at max is all i have on my truck. I don't see where you will have a problem with that set up.
Black steps | 5% limo tint | De-badged | Wedge Toolbox Lline-X sprayed inside and out | Bilstein 5100 set 2.8| 20x10 Fuel Hostage -24 offset | 35x12.50 Toyo MT | Tinted tails and third break lights | Black exhaust tips | Fold A Cover Tonneau Bed Cover | Tow Hooks
Old 06-20-2012, 09:37 PM
Thanks for the response
Old 06-20-2012, 09:54 PM
Rep:13
I'm just glad that i could be of some help.
Old 07-09-2012, 10:34 AM
jc0311 jc0311 is offline
Vehicle: 2012 Ram 1500 4x4
jc0311 is on a distinguished road
Hey whiteknight, your truck looks great. I just ordered my fuel revolver wheels, 20x10 4.5 BS with a BDS 4 inch lift cant wait to get them on there.
Old 07-18-2012, 11:40 AM
WhiteKnight, GREAT LOOKING TRUCK!
I got my Bilsteins (all corners), 1" coil spacer and wheels on order....
questions for yah!
- Do you get the 'wobble' in 4x4 mode?
- If you went with a lesser of an offset, i.e. -12 or 0 do you think you would rub with those toyo's?
- How are those Toyo's in regards to road noise? Slight hum?
- Did you notice a weight difference from stock to these? Im guessing so...
Thanks in advance and I love the white on black
Old 07-18-2012, 09:31 PM
Rep:13
questions for yah!
Thanks so much. I love the white on black look too.
1. No I don't have the death wobble
2. I think if i had went with any other offset it wouldn't have worked
3. Not to bad on the noise. I have had other mud tires so i know what
i was getting into.
4. Yes i did notice a weight difference. They weight 110lbs a rim and
tire.
Old 07-19-2012, 12:07 AM
i was getting into.
tire.
Thanks man!
I'm gabbing a 20x9 rims with a 0 offset.
I'm sure I'll rub with 35's considering I'll only be doing Bilstein lift/level.
110lbs is heavy. Think that's 20lbs heavier than stock.
Did you weight them?
Old 07-19-2012, 01:03 AM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Thanks man!
Ive found threads saying they will fit fine man i feel like I'm following you fast n ugly.
These wheels are HEAVY, its tough putting them on yourself.
