Old 05-31-2012, 04:33 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Supporting mods for camshaft.
Is it necessary to pull heads to replace springs on a cam swap? I read you have to get some tool where you don't have to? Also has anyone had their heads machined for them or is it best to stay away from that and just buy some all ready done? Lastly, what size are our injectors? And at what point would a new pump and bigger injectors be necessary?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 05-31-2012, 04:45 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
The shop that did my cam swap has the tool that made it unnecessary to pull my heads. No machining was neccessary for my 6.1 springs and rods. As far as the injectors go..... I'm not real sure on that. Mine seem to flow plenty of fuel for my application.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 05-31-2012, 06:41 PM
Color: RED<----
Rep:15
Awesome thanks, how's your truck running??
Old 05-31-2012, 06:51 PM
jpaul51's Avatar
Rep:167
Pretty dang good! I'm glad I finally got to get it done.
Old 05-31-2012, 07:06 PM
Color: RED<----
Rep:15
I feel the same way I will be happy like you in a few weeks :-)
Old 05-31-2012, 07:08 PM
jpaul51's Avatar
Rep:167
What cam are you going with? Getting a custom tune done at the same time?
Old 05-31-2012, 08:21 PM
Color: RED<----
Rep:15
Getting a custom grind from Stu at Inertia 210/218 then getting a dyno tune. With my supporting mods I'm expecting to see awesome gains!
Old 05-31-2012, 08:32 PM
I push the skinny pedal
Rep:3277
You don't need to pull the heads to do the swap. You can cheat and use compressed air to keep the valves in place while you pull the springs, just pull one plug and using a rubber bung with a tube through it, pressurize the cylinder, swap one valve spring at a time. I do recommend a valve spring compressor since it's the safest way when the heads are still on the block.
You don't need to upgrade your fuel system if you are just doing a simple can swap. Hell, on my heads, cam, intake, and nitrous setup Johan (my tuner) told me straight up to leave my fuel system alone until I either start running a 200+hp shot or get a blower. Once you upgrade injectors you have to retune the entire system to compensate for the new flow rates and pulse width, so hold off until you absolutely have to upgrade the fuel system to make the ruining easier.
Kurtis
Old 05-31-2012, 10:13 PM
Color: RED<----
Rep:15
Sweet yeah Ive never done a cam swap before so I'm leaving it to a buddies shop. Yeah I never hear anybody upgrading the fuel system so I was assuming we are set up good stock! Thanks for the info!
Old 05-31-2012, 11:35 PM
HemiLonestar's Avatar
Rep:274
It's only worth it if you have an 03 hemi, we got saddled with 10 less psi fuel pressure than 04+.
"Big Red"
2006 Charger R/T
