Old 06-16-2012, 02:52 PM
Robizzle0191 Robizzle0191 is offline
Vehicle: 1999 Dodge Ram 2500 SLT Laremi
Trim Level: SLT Laremie
Robizzle0191 is on a distinguished road
Kinda thinking along with the fuel guage not doing anything and no spark and not hearing the fuel pump prime that might be it. Is that a common issue?
Old 06-16-2012, 02:59 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Check fuses 3 & 6 in the PDC (Power Distribution Center under hood) and Fuses 9 & 11 in the Junction Box (Fuse box on left side of dash). If nothing else, pull them out and re-insert. Fuse 6 in the PDC is of particular interest.
brad
Interested in one of my mods?
Old 06-16-2012, 03:03 PM
brad12kx's Avatar
Rep:2581
Also take a really good look at the cable from the battery + to the PDC.
brad
Old 06-16-2012, 09:08 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
If computer is failed the check eng light won't come on. Like brad sed ceck fuses if those check out an you don't have a check eng light its a bad computer. If you have a cel light look into asd relay andd fuelrelay. Then fuel pump conection at tank.
Old 09-10-2012, 09:54 AM
So after brushing the truck of to the side for a little while I came back to it yesterday and noticed something very strange. My truck will sit there and crank but not start fuses all look good so i'm still stumped BUT and I don't know what made me even do it but I plugged a scan tool in and wanted to see if it would connect to the computer becuase if that connects then obviously the computers not bad. But I accidentaly turned the key to much and with the scanner plugged in my truck would start. It wouldn't stay running, I think the longest it stayed running was a second. It started and then the RPMs dropped, then came back up just a little then died. But the point is the truck would start with the scanner plugged in but not without it WTF. Any ideas
Old 09-13-2012, 09:43 AM
SHE LIVES! All this time and it was a stupid ground wire that came loose. Thanks to you guys that gave me all the suggestions I appreciate it. And remember if your car or truck runs while a Scanner is plugged in but won't when its not you got a loose ground somewhere.
Old 09-13-2012, 10:00 AM
brad12kx's Avatar
Rep:2581
Good find!
Let's hope the rest of your experience is much better.
brad
