ZDOG
Old 06-06-2012, 04:02 PM
blacklaramie98 blacklaramie98 is offline
Vehicle: 1998 dodge ram
Trim Level: SLT laramie
Rep:12
blacklaramie98 is on a distinguished road
Well fellas I got them in the mail today and they are identical to the picture? Maybe he was meaning they weren't the exact as picture but same style... Anyways here's a pic of one of them.also does anybody know where I could get some bright bulbs for the turn signal? Thanks
Old 06-06-2012, 04:11 PM
Vehicle: N/A
Rep:1045
Vleds.com or superbrightleds.com
Bulb- 3157. Both sites have many led options that are very bright. I've had positive results with both companies.
Old 06-06-2012, 05:10 PM
Rep:12
Okay and on your build you had switchbacks correct?
Old 06-06-2012, 06:18 PM
Vehicle: N/A
Rep:1045
Yes. They are awesome. I just recently swapped them for amber leds though. Highly recommend the swithbacks. Very unique look for your headlights
Old 06-06-2012, 10:08 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:47
Pyroboy5000 is on a distinguished road
tell me if you have problems with the driver side parking light connector going in. i just got mine, and now im having to mod my connector in order to get it to fit. the elbow on the connector interferes with the straight back flat part on the headlight. our headlights ought to be the same except for the top leds.
and btw my leds just pull straight out and they are the 194 wedge base bulbs. i peeled back the rubber, and its a wedge underneath. i dont know if your leds are the same. good luck with the install.
also could you post a picture of the back of the driver side headlight for me? it would help me a lot.
Confederate Ram TRX
Old 06-07-2012, 01:28 PM
Rep:12
Well I'm installing them right now but needed to check online for some LEDs but here's the picture. These things are veryyy time consuming. Oh well it will look good later on
Old 06-07-2012, 03:07 PM
Vehicle: N/A
Rep:1045
I like how most aftermarket heads for our rams are 1 piece units. About half of those aftermarket heads then have a mounting bracket behind the headlight, sposed to be better for aiming. I had a set like thatand they were very loose. The set you have mount directly to the fender, eliminating the bracket. Much more solid, that's what I have now.
Old 06-07-2012, 03:35 PM
Rep:12
I like the look of them I have one installed and here in a bit when I finish I'll upload some pictures
Old 06-07-2012, 04:11 PM
Rep:12
You wouldn't happen to have the bulb size for the actual headlight and the blinker bulb?
Old 06-07-2012, 04:56 PM
Vehicle: N/A
Rep:1045
Blinker is 3157
Headlight 9004, stock. Might be different with that projector.
