Old 06-01-2012, 12:32 PM
goatman65's Avatar
goatman65 goatman65 is offline
Vehicle: 2009 Ram 4X4
goatman65 is on a distinguished road
Default Spark plug damage - ceramic breaking.. what would cause this?
For the second time, I have discovered an issue with a plug. I was getting a P0304 code, misfire on #4 cylinder. When I pulled the plug, I found the ceramic on the center electrode damaged, thus, I thought there was a misfire to the head...
I used the compression of the cylinder to push out any piece(s), leaving the plug out and cranking it over.. although, I was not sure if anything was pushed out...
Replaced all the plugs, NGK-ZFR6F-11G 6987, which was the same as what was in the engine. I have had the ram for 6 months, 2002 1500 with the 4.7 and 130K.
After a while, the code came back.. I swapped coils and the injector, as it seemed I was getting a hydro-lock situation, and the only code P0304. I noticed a lot of white smoke when I was able to start it up after the hydro-lock.. Appeared to be flooded.. replaced the plug for the second time, and so far no code, no starting issue...
Anyone know what might cause the plug to fall apart?
Goatman
Old 06-01-2012, 12:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That is strange. Obviously it could be poor quality of the plugs, but since it's happened twice that's doubtful, and NGK is known to be pretty good.
I really don't know. Other than verifying that they are the plugs that should be in there(oem), I'm not sure what to suggest.
Sean
Old 06-01-2012, 01:07 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
That cylinder is getting to hot for some reason....you need to compression check the cylinders.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 06-01-2012, 03:42 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Red face Hmmm
it can be caused by a very lean cylinder, overheating the plug and causing the porcelain failure. Try a compression or leakdown test, look for any open hoses to that area , maybe even check thte plenum gasket?
Old 06-01-2012, 07:24 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
im sure you did, but id double check that you are running the proper heat rated plug.
http://www.ngk-sparkplugs.jp/english...q03/index.html
Old 06-02-2012, 06:23 PM
goatman65's Avatar
Default The result..
The white smoke was the clue..
During the compression check, she spouted like a volcano... the cylinder was full of anti-freeze... thus the Head Gasket... water being introduced into the hot chamber will cause the ceramic to break..
Goatman
spark plugs
