Old 06-01-2012, 02:40 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Default EBC brake noise
well i changed my brakes this past weekend and now i get a shaking/rattling noise from my pads. the stock pads had like little brackets that held it in place on the caliper, and the ebc just slide into the groove on the caliper, and i guess since its just sitting in there, any bumps make it rattle. when i apply my brakes they stock since they are being pushed against my rotor....is this normal?
-Pat-
Old 06-01-2012, 02:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The little brackets, are you talking about the little metal backing pieces on the pads? Like this:
If so, you should have reused that piece and reinstalled it. You should put some grease on it also. I think they make special grease for brake parts, sold in those tiny 1 oz $1 packets at the counter of auto zone and similar.
Sean
Old 06-01-2012, 03:33 PM
BlackHemI's Avatar
Rep:296
no, they have that part on them and it says ebc and all that crap, what im talking about is the piece that goes on the side, where the pad sticks out to slide into place. i threw my old ones away or id take a pic...
-Pat-
Old 06-01-2012, 03:36 PM
BlackHemI's Avatar
Rep:296
kinda like the clips at the bottom on here...but those arent how mine looked. they held the pad into place so it didnt wobble i guess
-Pat-
Old 06-01-2012, 03:38 PM
snrusnak's Avatar
Rep:1385
It's hard to see that picture, but I think I know what you're talking about. It's a small metal clip, very thin metal?
You weren't able to swap it from the old one to the new?
Maybe I still am confused....lol
Sean
Old 06-01-2012, 03:41 PM
snrusnak's Avatar
Rep:1385
This:
Yes those are anti rattle clips...
Sean
Old 06-01-2012, 03:43 PM
BlackHemI's Avatar
Rep:296
exactly, its the metal clip and actually i didnt try to because i had to bend them to get them off but i dont think they wouldve fit because the greens are so much thicker...maybe i can dig them out the trash
-Pat-
Old 06-01-2012, 03:45 PM
BlackHemI's Avatar
Rep:296
yea but mine like went into the caliper itself, unlike yours where its on the outside...and also mine were clips that had a tab that bent out to touch the caliper to hold it in place... do you think i can get those at the local parts store?
-Pat-
Old 06-01-2012, 03:46 PM
snrusnak's Avatar
Rep:1385
oooooh. Yeah you should have reused them. They should fit. They are sort of spring loaded, so you have to jamb the pads in there. I'd certainly put them back on, maybe buy new ones. I don't know but it may be possible that the pad could get crooked and cause issue with braking.
Sean
snrusnak's Avatar
Rep:1385
They probably have them. If not, then dealer.
Sean
