Old 06-01-2012, 03:54 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
im an idiot....
-Pat-
Old 06-01-2012, 03:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
im an idiot....
LOL
Hey we all do it. At least it's easy/cheap fix...
Stop and get a Whopper while you're out
Sean
Old 06-01-2012, 04:08 PM
BlackHemI's Avatar
Rep:296
heres a link to how my clips look, i was only able to snag 3 out of the trash lol
now i have to take of the caliper all over and compress the stupid piston AGAIN
http://i1171.photobucket.com/albums/...601_135657.jpg
-Pat-
Old 06-01-2012, 04:11 PM
snrusnak's Avatar
Rep:1385
I'd definitely replace them, they are pretty twisted. And I don't think you'll have to compress the pistons, the only reason you have to do that with a pad change is because the new pads are thicker than the old ones. Since you are reusing the same pads this time(of same thickness) they should go right back on.
Sean
Old 06-01-2012, 04:18 PM
BlackHemI's Avatar
Rep:296
ok great, now my next problem is to figure out there there were 4 total, 2 on each side and only on the from pad(not the one on the piston) or 8 total, 2 on each front and back...i think there were only 4, but ill go to the dealer anyways...
-Pat-
Old 06-01-2012, 04:22 PM
snrusnak's Avatar
Rep:1385
yeah not sure. If you can't figure it out, check a service manual, or worst case ask someone on here to take there's apart and take pics.
Sean
Old 06-01-2012, 04:41 PM
Mate2011RT's Avatar
Mate2011RT Mate2011RT is offline
Vehicle: 2011 Ram R/T
Rep:59
Mate2011RT will become famous soon enough
'Brake Hardware Kit' - should be able to pick one up at any Advance Auto / Autozone / PepBoys / O'reily - whatever is near and dear.
Also usually good to replace your slide pins and boots while you are in there, but that might just be my preference.
Hope it helps
Old 06-01-2012, 06:11 PM
BlackHemI's Avatar
Rep:296
I think there were 4 per side if I recall correctly. Thanks guys I appreciate the help! Reps yalls way
-Pat-
Old 06-02-2012, 04:45 PM
BlackHemI's Avatar
Rep:296
$10 and an hour later, they're fixed
-Pat-
Old 06-02-2012, 05:40 PM
snrusnak's Avatar
Rep:1385
Good times
Sean
