Old 06-01-2012, 06:13 PM
SilverRam318's Avatar
SilverRam318 SilverRam318 is offline
Vehicle: 2011 Bighorn Dodge Ram
Color: silver
SilverRam318 is on a distinguished road
Default 2011 Ram Clicking noise Help!!
For the last few days i have noticed a clicking noise coming from the rear of the truck when i hit the brakes it seems to be louder, but it is still there when im driving down the road. The truck is brand new and only has 16,000 miles so i cant believe anything is worn already. Any suggestions would be great thanks
Old 06-01-2012, 06:27 PM
Rep:2657
It is still under warranty, tell the Service Writer about it when you are there for servicing
also before you reach 36,000 miles or 3 years, which ever comes first, buy a extended warranty
i bought the Lifetime Max Care warranty, when i did it, what was remaining on my original warranty was pro rated & paid all but $1100 toward it
Old 06-01-2012, 07:47 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
Depending on when your truck was produced it may need to have the rear axle ported to allow fluid to reach the hub bearings. Is it coming from one side or both? Have you checked your tires for debris/nails, etc? Have you checked the brake pads to make sure it isn't the wear indicator (possibly bent)?
Old 06-01-2012, 10:40 PM
Trim Level: sport
Color: green
Rep:670
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
make sure the recall on the diff was preformed. some came through low on fluid.
Old 06-02-2012, 12:50 AM
Silverstar777's Avatar
Silverstar777 Silverstar777 is offline
Vehicle: 2014 Dodge Ram
Rep:19
Silverstar777 is on a distinguished road
I seem to be experiencing the same thing. I have a lift and gears, so at first I thought it was due to that, but I have torqued everything, and it stipp has a pop/click sometimes when braking.
Old 06-02-2012, 08:39 AM
Color: Inferno Red
Rep:71
This might sound basic, but have you checked the caliper mounting bolts? After my level, tires and wheels I had issues with my caliper mounting bolts backing out and allowing the caliper to move around. Threw some loctite quicktape on the bolts and it seemed to fix the issue.
Old 06-02-2012, 04:06 PM
Rep:19
I checked my caliper bolts. Still does it sometimes. Sometimes I wonder if it isn't the c-clip axle just making noise because of the play.
Old 06-06-2012, 11:04 PM
Color: silver
got it fixed, thanks for all the help guys
Old 06-07-2012, 08:20 AM
chilock chilock is offline
Vehicle: 2011 Ram Big Horn Crew Cab
chilock is on a distinguished road
So what did you find, as i now here this as well.
Old 06-07-2012, 12:22 PM
Trim Level: sport
Color: green
Rep:670
don't leave us hanging, what was wrong and what was the fix?
