Old 06-02-2012, 10:44 AM
drmjkm drmjkm is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
drmjkm is on a distinguished road
Default Hood Scoops
Anyone know the best way to remove the hood scoops on a 2012 R/T. I want to try some stuff but dont want to mess up. THANKS Don
Old 06-03-2012, 01:16 PM
Trim Level: R/T
No one?xxxxxxxxx
Old 06-03-2012, 08:18 PM
jdvelchek's Avatar
jdvelchek jdvelchek is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: R/T
Rep:86
jdvelchek will become famous soon enough
I put down some painter's tape on the top and bottom where the plastic meets the metal of the hood and used some plastic pry tools. If you don't have anything formal, there's always a kitchen spatchula... I put one under the bottom lip first, left it jammed in there and popped it out with another pry on the one up top. They are just molded plastic tabs that hold them into the hood. I guess you can take the heat cover off of the underside of the hood and push the tabs out that way too. That way, you don"t have to worry about chips or scraps.
Old 06-03-2012, 09:17 PM
Trim Level: R/T
THANKS. Don XXXXXX
Old 06-04-2012, 09:57 AM
Nightwalker Nightwalker is offline
Vehicle: 2003 Sport
Rep:16
Nightwalker is on a distinguished road
Try heat gun/hair dryer,heat it up little bit and try floss,tooth floss should work if you havent done it yet,good luck.
