Tires and Leveling - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-02-2012, 11:49 AM
Cotty16's Avatar
Cotty16 Cotty16 is offline
Vehicle: 2011 Ram 1500 Big Horn
Cotty16 is on a distinguished road
Default Tires and Leveling
Hi guys, I'm struggling with a major decision. I have been doin a lot of reading on leveling trucks. I have a 2011 Ram Big Horn and don't like the nose down look. I guess I have a few questions here.
If I do a 2" level will I even notice a difference. I'm scheduled to get it done next Friday.
Also, I am curretnly running the factory P275 60 R20 tires. I'd like to run them until they need changed. Will it look ok?
Basically, this is a famly vehicle and not used for offroading unless I'm going deer hunting in the fall and winter (which is pretty frequently). So, for the most part, this truck statys on the road for work and travel. I don't want a real aggressive tire. I do, however, want a tougher look.
Do you guys have any suggestions for tires that fit my needs? Should I go with 33's? Stay with my current size? Are my current ones like 33's?
Sorry for all the questions, but I really have no clue. I'm not afraid to admit it. Lol I posted a few pics of mine as it is right now.
I'm just not sure if leveling the truck will make that much difference. If any of you have pics of your trucks leveled with a similar setup, please post.
Thanks!
Old 06-02-2012, 03:12 PM
KR15's Avatar
KR15 KR15 is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: SLT Laramie
KR15 is on a distinguished road
according to this site (http://www.therangerstation.com/tech...nch_Tires.html) your current tires are about 33" tall so there is no point in getting different tires based on size.
it sounds like you would be most happy with a set of all terrain radial style tires if you don't already have a set like that on your truck. hope this was helpful.
Old 06-02-2012, 08:26 PM
Cotty16's Avatar
you know, I thought mine were close to 33's. Thanks for the input!
Old 06-05-2012, 04:38 AM
ecook280's Avatar
ecook280 ecook280 is offline
Vehicle: 2011 4x4 Quad Cab Big Horn
Trim Level: Big Horn Edition
ecook280 is on a distinguished road
I also have a 2011 Big Horn with the 275/60R20's, I have not leveled mine yet but once I do and my factory tires are worn out, I am looking at the BFG Rugged Terrain T/A's in either the same size or 275/65R20, the original size is a 33" tall tire just like our stock tires, the 65 series is a 34" tall tire. I am seriously thinking about going back to a 17" rim just to get a wider selection of tires, plus of course tire prices would be lower, would it make up for the wheel cost, not on the first set of tires but maybe down the road i would break even atleast
2011 RAM 4x4 Big Horn ... Let the modding begin :)
Old 06-05-2012, 02:38 PM
Rezboy's Avatar
Rezboy Rezboy is offline
Vehicle: 2006 Ram 1500 Sport 4X4
Color: Vanilla
Rezboy is on a distinguished road
Sounds like what ypoou want is a set of goodyear silent armour. They look like an All terrain but really are more moderate. I am in the same boat with the rake on my 2006 ram but the guys who are doing mine said the 2" leveling would be perfect and not effect performance. Don't change the tire size as the 275/60R20 size is fine and the ride is great off the road which really suprised me when I drove down in our pasture. Check with discount tires direct customer service and check onlinetires.com to see if they are cheaper. he is a link to the tire...
http://www.onlinetires.com/products/vehicle/tires/goodyear/275%252F60-20+goodyear+wrangler+silent+armor+114t.html
Old 06-06-2012, 12:20 AM
ecook280's Avatar
Thats a nice looking tire.
Old 06-06-2012, 09:11 PM
Jaytwo's Avatar
Jaytwo Jaytwo is offline
Vehicle: 2014 1500
Rep:15
Jaytwo is on a distinguished road
If you are just going for a level, I think a 2" is perfect, it will still have a tiny bit of rake. 2.5" seems to get pretty close for level, but you throw anything in the bed and you are now nose up. I installed the procomp lift/level kit which is 2.5 inch front and 1.5 inch rear. Drove around with just the front done for a few days, and didn't like it, put the rear on and now I have basically a 1" rake instead of the 2" from the factory. But it also lifted the truck up that amount.
Here is a link with the examples
http://www.ramforumz.com/showthread....hlight=Procomp
Old 06-06-2012, 09:19 PM
edd5's Avatar
edd5 edd5 is offline
Vehicle: 2012 Ram 1500 SLT
Color: grey
Rep:17
edd5 is on a distinguished road
The 2" lift will effectively level your truck to within about 1/2" or so. Anything more than that and you risk ending up with a nose up stance and then having to add blocks in the back to correct. You can run up to a 35" diameter tire with a 2" level, just watch the width. Anything over 11-1/2" wide will likely rub on the upper control arm and require spacers. I run an LT275-65-20 (34") on a stock suspension truck with no problems whatsoever. I like BFG AT T/A KOs since they look good and do everything well. Lotsa good tires out there by BFG, Nitto, Cooper, Toyo, Goodyear that will outclass your stock wranglers easily. Going with a larger tire than 33" will cause your speedo to be off a bit and will change your effective axle ratio. LT (Light Truck) tires are tougher but stiffer & heavier and will cost you a bit of gas mileage.
Old 06-11-2012, 03:54 PM
monettejb monettejb is offline
monettejb is on a distinguished road
Look up cooper zeon ltz. my buddy has them on aftermark rims and the look way bigger than mine. The crazy thing is its the same size tire as the FACTORY! Google them, and look at images. I may go with the 285 once I get my leveling kit on. I just have a 2wd but I will deff need the leveling kit. Is your's 2wd? or 4wd?
