Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 05-21-2012, 10:28 PM
Ramguy65's Avatar
Ramguy65 Ramguy65 is offline
Vehicle: 2014 Dodge Ram Sport
Rep:50
Ramguy65 will become famous soon enough
Default Tranny Shifting Hard
Lately I have been noticing my tranny has been shifting hard. It doesn't have that smooth shift that it used to have. I had my fluid changed around 6 months ago. I have also noticed a whine coming from the tranny when she is cold.
Anyone know what would be causing this?
Thanks!
2014 Ram 1500 Sport QC
Hemi, 3.92, Mopar Side Steps, Hemi Mud Flaps, Bakflip F1 Tonneau Cover, BT Catch Can, Magnaflow True Dual Catback Exhaust
Old 05-31-2012, 01:03 AM
Bluedodge0986 Bluedodge0986 is offline
Vehicle: 09 Dodge Hemi, Deepwater Blue
Trim Level: Lonestar
Bluedodge0986 is on a distinguished road
Check your differential, i had mine lose a bolt and i was stuck on the middle of the freeway with my driveshaft on the ground and fluid everywhere. Dealership said a bolt just fell out but had to rebuild my differential.
Old 05-31-2012, 07:53 PM
mopar09's Avatar
mopar09 mopar09 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport Regular Cab
mopar09 is on a distinguished road
My truck does the exact same thing except the whining sound from the tranny. I can be in park and whether I put it in reverse or drive. It makes a small grinding type of sound and kicks in gear kind of rougher than it should. I checked my transfer case and everything as far as tranny fluid and filter. All appears well and it drives fine. I don't know if this a common problem or not but I would at least have it checked. Hope this helps, and also to add you may want to check your differential.
-Justin(mopar09)
"If you can't Dodge it, RAM it!"
Old 06-06-2012, 12:48 AM
Ramguy65's Avatar
Rep:50
And I also noticed that when I go to put it into gear it sometimes takes a couple of seconds before I feel it actually go into gear. Is this normal? Would that be a differential issue?
Old 06-06-2012, 03:21 AM
Rep:2657
My Ram 2009 actually makes a grinding noise, every time that i shift into reverse
the dealer said it was the drive shaft
i told them that drive shaft don't make a grinding noise
they replaced it any ways
i still have the grinding noise & was told to drive it until it broke
that was over 20,000 miles ago, it still grinds going to reverse
sounds like an out of adjustment clutch in a standard shift tranny
