Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-01-2012, 02:08 AM
kennect2 kennect2 is offline
Vehicle: 2001 Dodge Ram
Trim Level: basic
Color: silver
kennect2 is on a distinguished road
Default 2001 Ram clutch cylinder replacement
My hydrolics went out on me, I have replaced the master and now am going to replace the slave. Bleeding the system is a challenge since there are no bleeder valves...any pointers would be greatly appreciated.
Thanks,
Kenkenwason1@yahoo.com
Old 06-01-2012, 06:12 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
It's best to bench to bleed it as much as possible (immerse the inlet in fluid and pump the rod until all the air is out). Then when you're sure it's full and all the air is out get under there and have someone hold the pedal down or brace it to the floor with a piece of wood and pull the seat all the way forward to hold it. Get under there and hook up the line and position it in the bell housing (don't pop the plastic strap!).
Once it's in there release the pedal and suck as much air up the line as possible.
Then wait a little while for the air to rise up to the clutch master. Make sure you're done with everything and it's in tight and pump the pedal a couple times.
