Seafoam treatment, same old - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 08-21-2012, 03:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
take the pcv off and get one of the big filters from advance, then you dont have to worry about the throttle body and intake gumming up for a lot longer as it wont be sucking oil in and it will not hurt anything venting this way
Don't do this! Those little filters are very restrictive and will cause excess crank case pressure, most likely blowing out a seal/gasket in time(usually the rear main seal on the crankshaft). Also, they will gunk up and become clogged in time. Also, they will make your engine compartment covered with oil/grease.
The pcv system is very good, only needing a new or cleaned pcv valve every ~100,000 miles. The valve is usually less than $5.
If you want to avoid gunk in the intake put a catch can between the pcv valve and the manifold, you'll keep the good pcv without causing other issues, and will keep the gunk out of the intake.
Sean
Old 09-01-2012, 11:20 AM
Exxzaust's Avatar
Exxzaust Exxzaust is offline
Vehicle: 2012 Ram 1500
Rep:24
Exxzaust is on a distinguished road
I just had an oil change last weekend, put seafoam in the truck including in the oil last night. Do I need to change it again ????
Dont be scared of the dark! Shine some light on it
Old 09-01-2012, 10:52 PM
snrusnak's Avatar
Rep:1388
How much did you put in?
The problem is that if you have "gunk" for lack of a better term in the engine and the seafoam breaks it up and it can clog the oil filter screen, causing a blockage in oil flow. With a newer vehicle it's fine I'm sure though. I've heard of this only on old(like 15 year old, 200,000 mile) vehicles that weren't maintained well.
Sean
Old 09-01-2012, 10:57 PM
Exxzaust's Avatar
Rep:24
i put maybe a third in, I was just reading that the seafoam breaks down the oil, well makes it thinner reducing its ability to hold itself and clean. I have been doing regular oil changes every 3000 miles so I would hope not much gunk would be in there.
So final verdict is im good till the next oil change in 3000 miles?
Old 09-01-2012, 11:01 PM
snrusnak's Avatar
Rep:1388
I'd leave it....and I'm pretty anal with my vehicles lol
Sean
Old 09-01-2012, 11:11 PM
Exxzaust's Avatar
Rep:24
good to know! Just one last thing ill add in I work outa town all week and leave my truck parked and only drive it on weekends, will this hurt it with the seafoam cause its sitting in there longer before I hit 3000miles?
And I was wondering what oil you use, weight, and filter!
Old 09-01-2012, 11:34 PM
snrusnak's Avatar
Rep:1388
It'll be fine. Just don't use it all the time. I'd only use it like every 50k miles or so.
5w20, I use amsoil as I get it really cheap. I use the "O.E. synthetic", it's their cheapest oil. It's good for whatever the oem recommended oil change interval is, but I just do mine at 5k miles. I use a WIX filter.
Sean
Old 09-01-2012, 11:38 PM
Exxzaust's Avatar
Rep:24
okay thanks im thinking about spoiling the truck with some royal purple and mobil 1 filter, can you bring those to the shop and they do it for you?
Old 09-02-2012, 12:22 AM
snrusnak's Avatar
Rep:1388
yeah most places will do that. In reality the oil doesn't make much difference if changed on time. Synthetic is definitely better and especially for the price(since you can get it at the same price as conventional). Use a good filter. Don't use a regular cheap fram, they are not good. The expensive frams are ok, wix, napa gold, mopar, many others....I'd assume a mobil filter would be good.
Sean
Old 09-02-2012, 11:28 AM
Exxzaust's Avatar
Rep:24
alright thanks! anyways we will keep this convo relavent to seafoam! Mine didnt smoke at all but i didnt put it in the intake because I didnt know what line to do.
