Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-03-2012, 03:56 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
Default Ram rt stall converter ?
Is there a way I can put this in my express and still keep factory warranty. Since the trucks power train is about the same except for gears. I already have 3.92 gears with LSD . And what kind if difference would it do for quarter mile and towing and such thanks
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 06-03-2012, 04:35 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
I would just go with an aftermarket stall. The RT converter is better than nothing, but you can do better with an aftermarket one. If you tow, then I would stick with a 2600 stall. From the outside, a dealership wouldnt be able to tell that the converter wasnt stock, and a 2600 stall isnt high enough to change the normal street ride any. You should be good to go.
Old 06-03-2012, 04:45 PM
Rep:79
O ok well the most I would ever really tow is like 4000 lbs so but I don't tow that much maybe twice a year "jet skis"
Old 06-03-2012, 05:00 PM
Rep:69
You will be fine with a little higher stall if you only tow 4k every now and then. Just remember that the higher stall you get, the higher you will need to rev the engine before the wheels start to turn. I would not go over 2800.
Old 06-03-2012, 05:14 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I think the RTs are rated to tow 5k with their stall so you'd prob be ok. Also, I doubt any of the mechs would be able to tell you had a RT t/c installed unless any of the lines, bolts, etc have a factory torque stripe on the threads.
but like hemi450 mentioned, you'd be better off getting a nice billet aftermarker stall (edge or circle-d) with a 2600 rpm stall.
Old 06-03-2012, 05:33 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
That statement isn't entirely true about a higher stall.....basically your truck will move at any rpm but from a dead stop it will spool up to whatever stall speed you have choosen before locking up. For instance my stall speed is set a 2800-3000rpm, I can take off normal just fine and it will shift through gears like normal well below that set stall speed,pretty much like stock. The difference is if I want to floor it from a dig it will spool up to 3000rpm right from jump street and lock up. You basically get that instant power vs waiting for the rpms to increase until you get into the meat of your power band. Also there's alot of torque management in these trucks and with the POS stock covertor it hinders it performance big time from a dead stop...thats the advantage with the higher stall (just about bypass the low rpm torque management). Yeah but like Hemi450HP an aftermarket stall around 2600rpm will be good for you if you do alot of towing and its gonna be night in day difference compared to the stock torque coverter set at 2300rpm.
BTW your 0-60' times should improve a good amount....maybe up to 1/2 sec off your quarter time as well.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 06-03-2012, 11:28 PM
Taylo1's Avatar
Taylo1 Taylo1 is offline
Vehicle: 2014 Ram 1500 4X4
Trim Level: Outdoorsman
Rep:88
Taylo1 will become famous soon enough
Are they building aftermarkets TC for a 2012 2500? Not trying to hi-jack this thread.....
Old 06-04-2012, 07:13 AM
CHVYKLR's Avatar
Rep:252
do you have the 65 or the 66?
http://www.ramforumz.com/showthread.php?t=113586
Old 06-04-2012, 08:16 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I'll agree with the others. Go aftermarket or don't waste the time/money. The RT converter doesn't compare to aftermarket. And higher stall rpm = more heat generated, which hurts towing.
I'll say though that I'd be comfortable towing 5,000lb with my 2800 stall behind my 4.7L.
Sean
