Old 06-03-2012, 09:35 PM
slasher012's Avatar
slasher012 slasher012 is offline
Vehicle: 2005 Dodge Ram 2500
Color: Blue
slasher012 is on a distinguished road
Default Building a chevy drag engine?
I'm looking for an engine for my 91 s10 drag truck I just bought. I really want to put a big block but everyone says that it takes a lot of work. But a friend says he's got a Jasper 350 out of a 87 blazer with tbi and only 32000 miles on motor. Said he'd sell it for $600 to me. Is this engine going to be worth getting as a base to build up or should I keep looking. It's my first all drag car and hoping low 12s maybe even 11s.
Old 06-03-2012, 09:48 PM
moparornocar72's Avatar
Rep:630
350's r easy and cheap to build and make power from. sounds like a good price!
14.268 @ 95 MPH Full Trim
Old 06-03-2012, 10:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^I agree. Chevy 350's have more aftermarket than any other engine. That makes parts cheaper.
A big block in an s10 is a ton of work. There's a lot of fitment issues, you have to modify the frame rails, firewall, and use slim radiator and electric fan which are both costly. Or use a pusher fan on the front of the radiator. It'd all add up real fast.
Also, they make 350 conversion kits that are affordable, that'd make the 350 a "bolt in" item...
Sean
Old 06-03-2012, 10:48 PM
Ram11's Avatar
Ram11 Ram11 is offline
Now 2012
Vehicle: 2012 Dodge Ram 1500
Color: Deep Red Pearl
Rep:146
Ram11 will become famous soon enoughRam11 will become famous soon enough
Its a 4 bolt main ,, correct
Factory Fender Flare's... Smoked Rain Guard's... 8,000 Hid'... Zeta Body Side Molding... Painted Pinstripe... Dodge S/S Door Sills... S10 Bed Slide... Ghost Flames... Mopar Tonneau Cover... Mopar High Performance Exhaust... K and N Cold Air Intake...Bilstein 4600 Front Shocks.....Thunder Form enclosure Loaded with 2 10 Kenwood Subs,,
Old 06-04-2012, 01:12 AM
Rep:2755
is it at least a 350/350
Old 06-04-2012, 10:21 AM
slasher012's Avatar
Color: Blue
I don't know anything about it except what I've already said. My real question is, is the jasper engine going to be worth getting so I can finish the truck in the next couple months then pull the engine in the winter to build it up where I want it?
Old 06-04-2012, 10:28 AM
snrusnak's Avatar
Rep:1385
Jasper engines are good products, but they won't get you to your goal of low 12's. You're only talking about 350hp max from that engine the way they come built. I don't know if the guy changed anything else, but 350hp in a 3,500 lb truck, you're looking at more like 13's at best. What transmission and rear gear ratio? That'll make the difference between 14's or 13's.
Sean
Old 06-04-2012, 10:29 AM
snrusnak's Avatar
Rep:1385
Also, since it's tbi, you're going to need the complete harness/computer from his truck.
Sean
Old 06-04-2012, 10:34 AM
slasher012's Avatar
Color: Blue
I don't have a trans or rear end for it yet. I bought it no engine trans and old owner stuck the stock rear back under it so it rolled and kept his rear. And I will be getting a carb intake for it so I don't have to worry about computers and lots of wires.
Old 06-04-2012, 10:38 AM
snrusnak's Avatar
Rep:1385
If you pull it out later and build it up, a different set of heads, a cam, and higher compression can probably net you ~400-450hp. You could always increase displacement too with a stroker kit. It's easy to make 450hp out of a 383 cid kit.
Jasper engines are drop in mild performance engines. Not really what you're looking for IMO. But if you get that good of a deal on a good engine, and plan to change it anyway, it's a good buy.
Sean
