Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 06-03-2012, 11:47 PM
igreer igreer is offline
Vehicle: 1988 w100
Trim Level: Custom
igreer is on a distinguished road
Default msd ignition
i want to upgrade my ignition system...if i install this coil...http://www.summitracing.com/parts/MSD-8203/ ......will i have to upgrade other things... spark plug wires distributor plugs etc...thanks
1988 w100
5.2
Old 06-05-2012, 01:16 AM
RC DuDe's Avatar
RC DuDe RC DuDe is offline
Vehicle: 2011 Ram 1500
Trim Level: 2WD SLT Crew Cab
RC DuDe is on a distinguished road
What are you trying to achieve? If everything is in good working order and you just replace the coil you don't have to replace other things.
Old 06-07-2012, 11:10 PM
Vehicle: 1988 w100
Trim Level: Custom
im going for a high performance ignition so if i out in a high performance coil should i do high performance wires and plugs to
Old 06-07-2012, 11:14 PM
Rep:3337
If you do a coil, you'll want to upgrade to a good set of wires and distributor cap. I highly recommend the Taylor wires and I'm blanking on the name of the cap I was running on my old Dak R/T
Old 06-08-2012, 02:58 AM
RC DuDe's Avatar
The reason I asked what you were trying to acheive is because the stock system is quite capable of handling many mods unless you're boosting and or spraying.
Is the truck needing a tune up anyway? Have you done any other mods?
Old 06-09-2012, 04:54 PM
Vehicle: 1988 w100
Trim Level: Custom
there isn't any mods to the engine...tune up probably not
the distributor cap is fairly new although its nothing special....with those upgrades though how much more power will i get?
Old 06-09-2012, 05:34 PM
RC DuDe's Avatar
I'd say save your money unless you were dressing up the engine bay. If you're looking for power start somewhere else. Just depends on your budget and how far you want to take it. This upgrade will not give you any HP increase.
Old 06-14-2012, 08:13 PM
Vehicle: 1988 w100
Trim Level: Custom
ok no HP...im learning not to trust what manufactures and websites say but some advertise that you will get an increase with plugs wires and stuff is this true?
Old 08-06-2012, 09:47 PM
countrygirl17522's Avatar
countrygirl17522 countrygirl17522 is offline
Vehicle: 1983 Dodge PowerRam W150
Trim Level: custom w150
Color: two tone gray
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
countrygirl17522 is on a distinguished road
Send a message via Yahoo to countrygirl17522
I did a tune up on my 83 w150 5.2 I put a blaster 2 that I already had in it with msd cap rotor wires and champion plugs. I quickly jumped up 4mpg. A blessing for an old carbuerated 8! (This is when I found out the idiot who tuned it up before I bought it had 2 different heat range spark plugs in) I've always liked the msd brand never let me down
Old 08-24-2012, 09:30 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
A good tuneup is always a good idea and if it origional plugs it probably could use one. It probably has origional wires also. Quality products insure that you will have a nice running and easy starting truck. better fuel milage and sweeter sounds. If you go with free breathng intake and exhaust.
1988, ignition, ignition coil, msd, w100
