wheel alignment?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-05-2012, 02:23 AM
dmac101 dmac101 is offline
Vehicle: 2012 dodge ram
Trim Level: laramie
Rep:39
dmac101 is on a distinguished road
Default wheel alignment??
i have a 2012 1500 with a 2.5 level kit. i have had a very slight wobble since putting it in which isn't my problem. but it seems to pull to the right didn't notice it before the levelling kit but also put the kit on within the first 2000 km, so it pulls right now weather level kit causing or not. i went and got a second wheel alignment after my level kit and it totally got rid of the wobble and the pulling, but then about 2000-3000 km later little wobble and pretty good pull back. i put brand new duratrac tires on it and it scrub off the corner of the tire on the side it was pulling.
so in all my question is. will a levelling kit cause moy truck to keep going out of alignment? if so, how or why?
if not what else could be the problem. a lopsided rim from facrtory that got moved from back to the front when tires were change? (just a random thought)
Old 08-05-2012, 09:14 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Rep:999
Hello dmac; well first thing I'd go over is all nuts and bolts torqued to spec. There were recalls on certain number of Rams for tie rods and wheel studs so inspect those two areas thoroughly. Good luck man.
