Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 06-04-2012, 07:16 AM
asendi's Avatar
asendi asendi is offline
Vehicle: 2010 Ram 1500
asendi is on a distinguished road
Default installing a class IV hitch
So i have a '10 1500 Laramie, but it came with out a tow package (a way for the dealer to keep the price down and gain on upgrades). and i wanted to install a class IV hitch. How do i even go about that. Not sure what parts to order and the difficulty of the install. The dealer isn't much help as they have no idea what they are doing. any suggestions/ pics?
Old 06-04-2012, 08:51 AM
boomerman's Avatar
boomerman boomerman is offline
Vehicle: 2012 Dodge Ram 1500 Sport
boomerman is on a distinguished road
The hitch install is really easy, it will jut bolt to your frame.
Depending on the hitch you may have to drill a few holes.
All you need to order is the hitch or hitch receiver as some companies call it that fits your model of truck
With a few hand tools and a little bit of time its easy peasy!!
That's really all there is to it.
Old 06-04-2012, 09:29 AM
h2oman's Avatar
h2oman h2oman is online now
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:387
That about sums it up..
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector. More AR's than you can shake an AK at.
Old 06-04-2012, 09:40 AM
asendi's Avatar
I was reading in the forums something about mounting to the bumper and mounting to the frame and how it affects towing. If I just get the OEM hitch receiver, that should be fine? or is there a specific OEM kit I need?
Thanks for the help
Old 06-04-2012, 10:20 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The hitch most people have is the class III hitch. It's a small plate basically, that bolts in right under the bumper. It is rated for 6,000 lb and 600 lb tongue weight.
A class IV hitch uses the same mounting points, but also has rails that extend to the frame on each side. It bolts to the frame rails as well as the center. It is rated for 10,000 lb and 1,000 lb tongue weight. It also weighs 41 lb more than the class III hitch.
I put the class IV on my truck, just because when I was buying a hitch it was on sale for the exact same price as the class III and I figured over kill is only going to be safer.
Class III:
Curt #13333
Class IV:
Curt #14374
Install of the class IV took me about 1-2 hours, you have to lower the spare tire, and a buddy's help(for holding the hitch up) helps as it's heavy. I'm sure the class III could be done in half the time with one person.
Sean
Old 06-05-2012, 08:56 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
If you didn't get the tow package, you should consider an aftermarket transmission cooler too.
Old 06-05-2012, 09:30 PM
snrusnak's Avatar
Rep:1385
FYI all 4th gen 1500's have the same transmission cooler. I'm not sure what the "tow package" gives you but the transmission coolers are the same in all 1500's (v8 anyway.....not sure about v6's...)
Sean
Old 06-05-2012, 10:43 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1206
You are half right, Sean. The tow package includes an additional transmission cooler, as well as an oil cooler and other goodies.
Mine had the tow package (had all of this), but it didn't have a hitch. Go figure. :huh:
US ARMY-RETIRED
2015 Ram 1500 Laramie Crew Cab 4x4. 50k Miles...LOADED...BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, MaxMate Stainless Side Steps, TruXedo Roll-up Soft Tonneau, MaxMate Stainless Bull Bar, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k HID Headlamps in projectors.
Old 06-05-2012, 10:46 PM
snrusnak's Avatar
Rep:1385
Where are they located? IIRC my truck has the "tow package" but only has a radiator, AC condenser/transmission cooler combo unit, and PS cooler.
Sean
Old 06-05-2012, 10:48 PM
snrusnak's Avatar
Rep:1385
well I don't have "tow package" on my build sheet, but the following is listed:
NHDP Heavy Duty Transmission Oil Cooler
NMCP Heavy Duty Engine Cooling
Sean
