Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 06-04-2012, 01:37 PM
525pete 525pete is offline
Vehicle: 2012 ram
Trim Level: st
Color: silver
525pete is on a distinguished road
Question remove panel ?
2012 ST -- how does the panel below the heat/AC remove ? I want to mount a CB radio, and want to remove the panel to drill/mount the bracket
thanks, pete
Old 06-04-2012, 08:33 PM
RC DuDe's Avatar
RC DuDe RC DuDe is offline
Vehicle: 2011 Ram 1500
Trim Level: 2WD SLT Crew Cab
RC DuDe is on a distinguished road
Remove the rubber tray above the radio. It will expose 2 T20 torx screws. If your truck has the 110V outlet on the right hand side you'll have to remove the outer trim piece around the outlet exposing another T20 torx screw. Once you remove the screws you'll have to pry the bezel out between the dash. The bezel is held in with a lot of clips. I think a dozen or so. I made a plastic pry tool out of some bicycle tire levers by grinding the end down and making a smooth thin flat end. Just be careful as you pry between the dash and the bezel. I started in the top outer corners. Once you get that bezel off you'll understand the rest.
Old 06-04-2012, 10:07 PM
Vehicle: 2012 ram
Trim Level: st
Color: silver
ah, I have to take off all that stuff to get that lower panel out ?
I had hoped there was a way to get it out without disturbing the upper stuff. oh well !!
thanks, pete
Old 06-05-2012, 12:35 AM
RC DuDe's Avatar
Yes everything is secured behind those panels.
