After headers - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-04-2012, 05:53 PM
07yt1500thunderroad's Avatar
07yt1500thunderroad 07yt1500thunderroad is offline
Vehicle: 2012 passat tdi se w sunroof
Rep:70
07yt1500thunderroad will become famous soon enough
Default After headers
I was getting around 15-17 around town on my truck then i added headers. they have been on the truck for almost a year and the highest it has gotten has been 13mpg. I have hedman shorties, going into stock pipes until the muffler, then a 14" magnaflow and dual 2.5" pipes one out of each side. I am afraid that some of my other exhaust components might be restricting me now. Does anyone know for sure what else i need to do?
Old 06-04-2012, 07:24 PM
moparornocar72's Avatar
Rep:630
It shouldn't have gone down unless u have ur foot more in the pedal. Try using cruise control and easing up on ur driving if u are on the gas a lot and see what u come up with before spending anymore money!
14.268 @ 95 MPH Full Trim
Old 06-04-2012, 07:32 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
My longtubes knocked my mileage from 22 down to 20 on the highway. Altogether my average mileage went from 17.5 to 16.5. I'm thinking I'm running a bad air/fuel ratio..
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 06-04-2012, 08:59 PM
Rep:70
As far as the mileage it wouldn't bother me so much but i only gained 1th of a sec on my 1/4mile time. The truck seems to run better but by the mileage and 1/4 mile time it acts like now with the more open manifolds (headers) something else might be holding me back...could it be the tune, im with ramrt1993 maybe the o2 sensors are reading higher levels of emissions and altering the computer.
Old 06-04-2012, 09:47 PM
Rep:3347
you should be running a CMR tune for sure to account for the changed air flow and scavenging from the headers, also a MAJOR restriction in the system is the stock y-pipe, you need to get rid of that thing ASAP
Old 06-04-2012, 09:54 PM
Rep:70
anyone have a video of before and after installing an aftermarket y pipe?
Old 06-04-2012, 10:12 PM
Rep:3347
No video, but if you go look under your truck you'll see that it's two pieces of pipe squished together to fit into the SAME DIAMETER of pipe which is horrible for flow characteristics. One of the first mods most do to their exhaust system is pull that abortion out and replace it with a quality y-pipe like the magnaflow one. Mine was part of my header kit.
Old 06-04-2012, 10:40 PM
Rep:70
Well you got me...lol i have one on ebay right now!
Old 06-05-2012, 03:59 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
yea, the y-pipe replace was only 30 bucks, then another 30 to install...best cheap mod by far! but im going to have to say you need a tune, i guarantee you itll be better once you do!
also, did you have the same size tires as before??
-Pat-
Old 06-05-2012, 04:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
What tune do you have? Headers with most canned tunes will cause a lean a/f ratio. Although, this is normally only with longtubes, not shortys. This could be part of the problem though.
Also, did you run the truck with open headers or anything like that(even for a short period of time)? If the O2 sensors are near the end of the exhaust pipe when the engine is running, it will ruin the O2 sensors. It is possible to have bad O2 sensors without a check engine light.
And you still have cat's right? With the O2 sensors hooked up(both upstream/pre cat sensors and downstream/post cat sensors)?
Sean
